18 hours ago, SS502 said:
Looks factory to be honest...does it block off the turn signal?
Look's Good
On 3/30/2018 at 12:19 PM, Marv88 said:
Re upholstered jump seat in leather. You can get the kit leftovers from trucks that didn't need them due to having a full console at local upholstery shops or on eBay for less than $50 bucks.
Got any link?
Got any link?
I just bought mine from a member here a week or 2 ago. They show up on Ebay from time to time as well. Last I checked there was only a cocoa and dune colored set on Ebay, you just have to keep an eye out for the black if that's what you need/want.
Sent from my SAMSUNG-SM-G890A using Tapatalk
On 7/14/2018 at 9:57 PM, Deadpoollane said:
Are your turn signals tinted?
3 hours ago, H-town Silver Bullet said:
You looking for jumpseat?
I have mine in garage but without internal wiring.
Im in Houston
I'm looking for a leather skin, is yours a complete jump seat?
39 minutes ago, H-town Silver Bullet said:
Its cloth.
But complete minus wiring
I've got a cloth jumpseat already but it's greyish but I wanna make it black
Thanks though
CF8A4873-D42E-4E66-B166-5AE7B82DC224.thumb.jpeg.d5d9c89098b1528b4f145add5040d20e.jpeg41162B01-2A24-41B1-8AF2-1E700558DC8C.thumb.jpeg.8fe06addff13fccb41a8ac3a3f840650.jpeg4878A11F-DE21-4B95-9C48-27F40361A772.thumb.jpeg.acd79b6281bfa7e199516cb863cfc361.jpeg41690D0A-0AEF-4EA1-B941-7899D586FAA0.thumb.jpeg.de0826ecc270d6a327b459c11b38b91c.jpeg
Swapped out the drivers A-Pillar cover for a Driver's Assist Handle, last Sunday.  $52 for the part thru Amazon Prime, and about 30 minutes total to remove the original cover and install the handle.  The close up of the upper end, was cause some of the guys were complaining that it didn't lineup.  Once I got the leash from the original cover tucked away, it mated up flush.
Edited by Ravenkeeper
  • Like 4
Swapped out the drivers A-frame cover for a Driver's Assist Handle, last Sunday.  $52 for the part thru Amazon Prime, and about 30 minutes total to remove the original cover and install the handle.  The close up of the upper end, was cause some of the guys were complaining that it didn't lineup.  Once I got the leash from the original cover tucked away, it mated up flush.
That’s one of my few dislikes with my ‘15, had no clue they were out there. Got a link by any chance?
Google 23285090 for the gray one...
https://www.thepartstruck.com/oem-parts/gm-interior-assist-handle-23285090?c=Zz1pbnRlcmlvciZzPWRvb3ImbD0yJm49U2VhcmNoIFJlc3VsdHMmYT1jaGV2cm9sZXQmbz1zaWx2ZXJhZG8tMTUwMCZ5PTIwMTcmdD1sdCZlPTUtM2wtdjgtZ2Fz
As it happens I was planning on ordering this. Cheaper than amazon, albeit no prime shipping. Came out to $47 total I think with shipping? **make sure your color is correct**
I used Amazon, to save me a 80 mile round trip.  Most definitely make sure that it’s 23285090.  Worth the $52 I spent, far less than the cost of the item, and two round trips to the dealership (one to order and the other to pick it up).
https://www.amazon.com/Genuine-GM-Molding-Pkg-Part/dp/B00TA7UUM2?keywords=23285090&qid=1547714442&sr=8-1&ref=sr_1_1
It that an Air Bag I see ?.....is the new trim compatible with the Air Bag (if that is what I'm seeing ?)
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 592 Guests (See full list)
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
