Ordered a whipple! Anyone that's got any tips or insight plea
Denali62
Well I was wrong about thst. Bumped up my wot shift points and changed my revs per mile for the 37"
  • Replies 194
And now it seems i have stripped or broken my output shaft or t case input...
Towed back to dealership.
Yay. Lol
Ended up being my input shaft. Gm is also done paying so its at my cost.
I'm really hoping the z06 has an upgraded part that will work but I probably won't get that lucky.
They are wanting to replace the trans for just north of 4k :-\
What in the hell were you doing that you broke the input shaft?
If GM isn't going to pay for stuff any more I suggest not utilizing them for work moving forward.
I was running the zo6 trans tune with no tq reduction on shifts and dropped from 8 to 3 which Always causes a bang. It was very abrupt lol.
If I shift down to say 5th then floor it it is smooth as butter so ill just have to modify my tune to not allow that situation to occur
They are working with me on the costs. And upgrading me to zo6 spec. Plus the truck is an hour away from my shop so I'm just gonna let them handle it this time. Everything else from here on out will be done at home loll. Still waiting on my whipple which is getting ridiculous
Also im asking about keeping my old trans and tc. That way I can have a spare and hopefully find some beefed up components and have my tc built
Called Maryland speed today and was told that their supplier crapped on them pretty much And they awarded me 300 in store cstdit! So technically I got the blower for 5k! When I do get it that is...
Should be ready tommorow. 4292 plus tax. Tack on 1500 for me to keep my core trans and tc
I'm wondering where I should send it to be beefed up. I guess ill call circle d and ask.
Ok I'm officially a dunce. Broke the new input shaft in 3 days. Sending my old trans to circle d to be gone through/input replaced. The whipple is coming so I will have it on when I get it back together.
Its something in the zo6 trans tune that is causing it in sure at this point. So ill be going back to the stock tune and mAking changes from that. Live and learn.
You may want to iron out your tune or driving style before you add 100HP to your truck. I have a 92 truck with a stroker and whipple running 12 LBs of boost. The 700R4 trans has stage 2 build with one rebuild in 10 years and is now 10 years old. The rear end is a stock 373 with 120K miles on it. I've been building driving stuff like this for 40 years and learned real quick something has to give, unless I'm playing at the track it the tires. I rather break them loose than break a hard part. I'm not knocking you but it's more fun driving and improving than fixing broken stuff.
I found the cause and have corrected it. But yes if not I definitely woukdnt be adding the boost. Or meth injection
I'm sending my original trans first then when I get that back ill send the one currently in the truck. Looking into switching to a billet converter, as well as switching back to a 35" tire and installing oem 3.73.
Just wanted to follow up:
Sending my stock trans along with a new input shaft to circle d today.
Whipple ships on the 4th with 3.625 pulley
Branden at Maryland speed is covering the costs on an elite catch can with dual check valves and clean side separator
  • 1 month later...
Just wanted to follow up. I know you guys probably disregarded the project entirely but I have been chipping away. Ended up with
Whipple with 3.625" pulley
Vengeance/wiseco forged drop in pistons
Brian tooley blower cam w 38 %lobe
Platinum .660 springs With ti retainers
Morel lifters
Katech dod delete valley pan
Lt4 head gaskets
Comp vvt limiter kit
C5r timing chain
Alky control single nozzle on 100%
Straub bushed trunion upgrade
Kooks 1 7/8 with off road y into Walker btr muffler with a 3.5" muffler bypass off a qtp cutout that dumps back into the tailpipe after the muffler
Elite dual outlet with check valves and clean side seperator
Katech 103 tb
Afe momentum hd
Caspers iat breakout harness
Ls9 map
Etc
Should be done with all the installs by the first of the month
