Looks like another change of the EVAP. Did the part you replaced be an AC Delco part?
At least you don't have to pull the bed like I did to get to it.
As for the fuel pump, it will cause hard starting. Best way to find out is do check fuel pressure. I got a loaner gauge from Auto Zone to check mine.
BOught a Dorman part both times (replaced 6 months ago).
Dorman 911-032 Vapor Canister Purge Valve
I went and filled up and it started fine. Code hasnt come back (yet). Hopefully this thread will help others. The fix is like $20 and maybe 5 mins of work.
Your original problem was no start after refueling, my response is the same. Your purge valve is stuck open, weather you've changed it or not before.
Just an opinion, but........
When it comes engine metering, I would stick with stock components that were labeled Delco, Delphi, or GM - only.
Some of us had to learn the hard way.
I have had good luck with Dorman parts in the past, we will see how this one goes
Truck ran flawless today and it hasnt the past few wks.
Another fill up and a week of cold (freezing temps). No issues truck is firing right up again
  • 4 years later...
I replaced all the spark plugs rapidfire Delco every part on my truck is completely brand new not saying that something did not break or go bad I know parts go bad I’m having trouble hard start turns over over but don’t start then when it does start sounds like it has a cam in it changed all the injectors brand new check for vacuum leak with brake cleaner replaced all O2 sensors by the way I’m having a low-voltage high-voltage or bank to downstream replace the plug off the main harness didn’t change it I know I have a short somewhere my problem is the truck is not wanting to start when it starts it is completely smells like it is flooded at first I thought the fuel pump it’s brand new change pressure regulator brand new same time when I did the injectors and the plugs But she is running horrible when she does start multiple misfires and then it goes away sometimes and here’s the FYI sometimes I get her to fire right up first time Confused don’t know where to go I have $23,000 in my 2001 Tahoe everything down to the brake lines every charcoal canister every electrical component fuel everything my battery has been acting kind of funny lately I’m going to try changing the fuel pump relay to see if that works any help would be absolutely amazing guys took out the fuel pressure regulator in about a gallon of fuel shout out so has good pressure And change the fuel filter lost I even replace the valve cover with the new system on the driver side I love my Chevy wouldn’t drive anything else please help if you can
I had those symptoms once. I got a load of water in the gas from an unfamiliar station. I had to have the tank pumped out.
Edited by Beamie
Pump the tank out I had some water in the fuel I hit a water puddle about a year ago but I don’t think it’s from that I thought it was for maybe a gas station kind of the same as you I did replace the purge valve solenoid yesterday and it fired right up I’m still getting a lien code or bank to downstream O2 sensor but I just replaced it may be bad part I may be a short in the wire for the roof I bought some fuel out of the where the fuel filter is into a glass jar
found so water in fuel I ordered the oil catch can
