CB Radio
Lalibert
Looking for ideas and suggestions of antenna mounts and radios. Would prefer to not have a mag mount on the roof, I have looked at the stake mounts but they don't look very clean, also looked at mounting on the front side of the bulkhead of the bed (currently have a Tonneau cover) but concerned about clearance and rubbing on the cab. Also how have you run the radio wire into the cab?
Right now, pretty much anything Uniden is about the best CB you can get easily. Personally, I'd buy a used radio...Cobra 29 or Uniden 76. The Uniden Pro (Pro 510 or 520) series was a small footprint deal also...
As for the antenna mount, it's all about what you want to do...do you want good performance or good looks? I ran a 102" right on the bulkhead...I currently run a Wilson 5000 drilled in the roof. You have many options...
Yea currently have a Wilson 1000 and cobra 29 on the 04 Silverado and get good distance out of it. I only use the CB for hunting season and only need a range of 3-5 miles. I would rather go with something a little more sleek, thought about the Firestik 4 ft Firefly or the Wilson Flex Antenna and mounting it on the bed some how. I also read some good reviews on the Cobra 75 WX ST which would allow me to just toss it in the center console for the other 9 months I am not hunting.
Make a bracket for you magnet mount on the front lip of the bed...when hunting season happens, put it back on the roof.
I have mixed feelings about the Cobra 75...probably decent enough, but they are pretty much a throw-away.
You can purchase one that sticks to your window. Kind of looks like the older phone antennas. I had one on the back glass of a Colorado once,not as good as a good magnet mount, but it worked
I've never had one of those through-glass that worked...
This is my set up and works very well with a perfect SWR.
So I picked up the Cobra 75 and thought about mounting it under the driver seat given how small the module is and it also allows me to easily discount the mic/main controller, figured this would be easier than running everything into the center console, so is there a constant power source I can tie into under the seat rather than running it to the fuse box?
I stumbled on this thread looking for ideas people had on getting the coax from cab through firewall. Here is the way I'm planning on mounting the CB I got for Christmas: I like the almost factory look that you end up with. I got the mount and cable from mt local HAM store, and will begin surgery once I settle on the best route for the wire (That wire isn't as pliable as a power cable!).
http://www.ford-trucks.com/forums/737609-cb-mounting-antenna-mounting-wiring-questions.html#post6110561
You can see my Wilson 5000 on the roof (through-roof mount). That gives me solid 1:1 SWR and good performance.
I've tried running fiberglass antennas the fender, on the door, on the mirror, on the rear quarter, on the rear bumper, and on the front bed rail. I've never gotten the performance out of them as I have a Wilson or a 102-inch whip. Maybe I'm too picky...
There are a couple other threads out there on this subject. Here's what I did with mine.
Mounted the antenna in the forward right stake hole.
Mounted My CB Antenna
Put my CB and scanner in the center console.
Installed My CB & Scanner
I'm looking for some black foam to dress around the radios. My next project for them is going to be installing my linear amp and/or HAM radio.
RK what brand/modwl of scanner are you running? Do you use it in conjunction with a radar detector?
The scanner is a RS special with wide range of freq's, don't recall the model # of hand. I do NOT use a radar detector, don't need it, don't speed.
Scanner? Oh I remember those! Can't use em anymore here, at least for Law Enforcement/FIre/EMS :( Everyone went to digital trunk systems :( Phooey.
73s.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
