I ran them on my 2007.5 - They do come with the adapters - just pick the one for GM - I have emailed PIAA to confirm 2017 fitment........
Please let us know what they say.
Thanks!
One thing to consider with the wipers is when you buy a truck off the lot, think that the wipers have been sitting in the elements not doing anything since its build, could be months, just drying out. When we replace wipers, they're used all the time with washer fluid, in the rain, multiple times to keep them hydrated. Its not that the ones that came on the truck are garbage, it could just be that the truck has been sitting and they've dried out. Would happen on any vehicle that sits for months and not used the wipers. I run the OEM ones on my truck, first set lasted 2 years, replaced with OEM and so far so good.
Rain x washer fluid is great to maintain the repellant coating, but nothing beats a hand application of the real stuff
I recently replaced mine with Bosch Icon OE and was really impressed. Much better than the factory wipers
The left wiper streaks all the time on my '17 All-Terrain. Only have 4500 kms on it. I'll be replacing them STAT!!!
I would tell your dealer you want them replaced. Wiper blades are not officially covered by the B2B warranty but at under 3000 miles you shouldn't be having problems with them yet.
I'll let them know when I bring it in for the first service.
Thanks for the advice.
I have had good luck with PIAA Silicone. Mark me down as a fanboy for Aquapel, it lasts 3 or 4 times as long as Rain X and doesn't smear when it wears out. With a good coat of Aquapel on your windshield you can get by with just about any wiper blade.
32000 miles on OEM blades. No problems at all. I do use RainX applied and their fluid,
Thanks!
PIAA has confirmed the part number is still # 97055:
Thank you for contacting us. We do make a wiper for your 2017 Silverado 1500 truck. It uses our Si-Tech blades part number 97055. You can find them in the link below.
https://www.piaa.com/store/p/121-22-550Mm-Si-Tech-Silicone-Wiper-Blade.aspx
Jamison Niebuhr
PIAA Corporation, USA
503-489-6616
The Road to better Visibility starts with PIAA
Visit us at www.piaa.com
Edited by Krusty
Jamison Niebuhr
503-489-6616
Thanks for this!!
Edited by KA0S
Wiper blades on my sucked the first time I used them. I recommend the Bosch Icon as well, but dang they're $50 for a pair.
Try Amazon or Walmart. I got them from Amazon for $34 with tax
Never thought about Amazon, and I'm a Prime member! thanks!
Before you buy anything, always look at amazon. It saves me a lot of money every year.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,278 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
