2017 f250 6.7
Has anyone drove this truck? Wow. The quality and everything is amazing.
I own a GMC but wow. I'm strongly considering a trade later in the year maybe.
  • Replies 44
You're not kidding. Also that DEF tank ruined the 3/4 ton for me.
Fords new LED lights on the super duty is just amazing. I checked into the king ranch trim and holy moly this thing is nice. Ford did an amazing job on the new design.
I'm not brand loyal but I've been looking at these things because I plan on buying a diesel
I just bought a Silverado. I tried some Rams and Fords. They are nice but still don't have what GM has in my opinion. Towing, hauling and mileage are all comparable. Most of the technology is unused as it is so I don't care if they add more. I like the GM trucks and would be really, really hard pressed to unload mine to get in a Ford or Ram no matter how sweet they may seem when new.
Lots and lots of hard, cheap plastics on the XLT and Lariat trims. I def. wouldn't call that amazing and or quality. And most of those trims had a vinyl textured steering wheel not leather wrapped.
In my view, from least exciting to most exciting:
GM
Ford
Dodge
And from least reliable to most reliable:
Dodge
Ford
GM
I don't need exciting. I want to get in my truck 200k miles from now, drive deep into the north Idaho wilderness, and not have the first inkling of doubt about whether my truck will get me back out. I bought a Chevy.
I saw a couple at the RV park last week. I always like to check out the other 'rigs' to see if there's anything that catches my eyes. A lot of folks have a ton of money in them. I saw a couple of the new CCLB DRWs. Looked great to me. I love the look of my 2500 Dmax though so I'm not in a hurry to trade for a Ford. I agree that the DEF tank sucks on ours though. I'm waiting for someone to come out with a lower profile replacement. Can't believe no one has yet.
We have a pair of 2016 F350 trucks here at work. I know most fleet vehicles are beat, and misused, but these trucks are junk. The fuel tank vents get plugged and then won't take fuel, the air conditioners plug up because the condensation attracts coal dust and then they plug up, the electrical system won't support anything extra, (two way radios drain the battery requiring weekly jump starts, and the list goes on. I don't care, however, I've never been a ford fan, and never will be.
To each their own. I know saying this on a gm forum people will say what the want and that's fine as far as cheap quality the same is said about gm on ford forums.
The entire inside of the king ranch is leather! Even the steering wheel and the cab is very roomy and set up a little better - at least to me it is. The duramax has 5 more horsepower on paper but they are both amazing trucks.
Also the 17 hds the hood scoop has a catch bag for water that you have to drain out- did not know this!!
When it comes to 1/2 ton I'm gm loyal the trucks look better but when it comes to 3/4 ton... ford takes the cake in terms of looks and setup on the inside to me
My experience has been that the Ford looks nice inside until you touch it and in that sense is not as high of quality to a GM. Ford does offer better features and creature comforts on the interior.
I've had better experiences with GM drive trains and suspension.
GM is better engineered, but susceptible to lowest bidder for parts supplier and like all manufacturers are mass produced on an assembly line so is comparable in build quality.
Aluminum body, I'm not yet convinced.
Have you seen the crash test videos? The body is still strong as hell.
They even E coat their frames now for rust prevention.
Everyone else just waxes their frames
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
    • Just saw on Jay Leno the new Scout. That’s the way it should be done.
    • EV's have their nuances too. Best to operate the current type of lithium batteries between 20-80% charge. No real need to charge until you hit around 20%. Occasionally charge to 100% when needed. Longer term storage, battery should be 50-60%. At least those are the guidelines for our iX. We've been exceptionally good to the battery in that car...easy to do when you can charge at home like we can.   EV's lack so many of the rituals and so much of the visceral feeling ICE vehicles provide, which is why I think they're hard to accept for a lot of gearheads. They're fun in different ways, though.
    • We have got a lot of rain lately, we needed it. Storms/lightning took out a floor fan. Dirt roads badly rutted from run off.   Power here is sketchy, whole house surge protector in the service panel and all electronics plugged into surge protectors. My biggest concern is my stereo, I've been an audio nut for years. $25 k in equipment. Stereo is on it's own special surge protector.
    • Happy Birthday!  I also turned 72 this year.  In some groups I consider myself to be a young senior and in others I realize I have serious years behind me!  In June I spent a week in the hospital due to a blood clot following knee replacement surgery.  The hospital Doctor assigned to my care specialized in Geriatric medicine!  He is a great Doctor but the fact I required this type of specialized care  made me feel old!  Aging comes with new challenges but I sure appreciate getting older!  It most definitely beats the alternative!!
