All terrain LED tailight assembly swap
Has anyone done this. I like the look of the tail light and of course its LED. Is there an OEM PN# we can order? Does the 1500 and 2500 have the same unit? Hopefully its plug and play.
Thanks for the links. Boy this is a pricey one at around $1000. The regular cheaper auto sites like GMParts direct say they have discontinued the part. Hmmm.
eBay you can get tails for $700 and the harness for $100.
^^^^^^ zmnypit,Thanks for the info. I also read that if you don't do the fronts that the regular incandescents will load the turn signal line enough to make it work. May be wrong but you can correct me if you have the experience already.
Nope. Rears and fronts are separate. I tried just installing resistors on the front only and the rears give me an error on the dash.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
