Truck is wired for them but only mandatory in the UK.
Do you know where I can find the wiring for rear fogs?
Would they come on with the front fogs?
Never understood why this isn't even an option.
Same with adjustable headlights.
so long
j-ten-ner
so long
j-ten-ner
It isn't requirement here in North America so domestic car companies have no reason to do it. German and a few other European car companies must include them on their vehicles sold in Europe, and for simplicities sake do not engineer a whole new taillight assembly for the US bound cars.
Probably for the better to be honest. You have idiots in their Audis using them on clear nights blinding and confusing other drivers who do not understand what rear fog lights are.
Basically American drivers are just too stupid to be given another feature they must control on their own. Every idiot with 20/40 vision can get a license here.
Fair enough.
As far as I know, lane departure warning is also not required by law. But it's offered as an option.
You're right, many drivers don't even know how to use a turn signal or when to turn on fog lights.
That's why you see them driving around in broad daylight with the fogs on. Maybe because it looks "cool".
I'm sure that my headlights are better to see in the fog for other drivers than the weak tail lights.
The front fog lights are designed to illuminate the road right in front of my car.
To give me better visibility and not for the "others can see me better" argument.
But the rear fogs are. The sole purpose of the rear fogs IS to be better visible for drivers behind me.
so long
j-ten-ner
so long
j-ten-ner
Well I may have written that to quickly without verifying, it is in the BCM menu as rear Fog light enable and rear trailer fog light enable but nowhere did I see actual pin-out for rear fog lights or connector end view with these. So my bad for assuming. This of course was for a 2011.
Re: rear fogs
Typically I've only seen them on British cars and a few German ones. I usually just turn my hazards on in extreme rain or fog
Edited by Sean403
My neighbour has an Oldsmobile Aurora that has them.
Rear fogs generally have a separate button/switch and most likely even if it is in the BCM, wiring would be different as would tail lamps since basically the rest of the world requires amber for rear turn signals.
Or we can just program your BCM to remember the last state of the switch ;)
Nope not even in the menus of the TechII unless you have access to more options.
Well if you are using a Tech 2 on a global A car that might be your first indication that something is Amiss.. LOL (this is in the 2014+ section) same could probably be done on the older trucks we'd just have to work it out.
    • Couple plausibilities.   - Bent pushrod   - Bad injector   - Roller lifter failed and has been eating the cam lobe(s).     - Broken valve spring   All are options.  Most common that I can recall would be the valve spring (hard to see the break on it as well), the cam/lifter and the injector.
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
