The goodyear sr-a's have died!!
Well its a happy day for me i got new rubber on her. Man she looks nice
I wanted falkin wildpeak at3 or the nitto ridge grapper but they didn't have it in stock so after the sells man showed me some tires i got these http://www.discounttire.com/buy-tires/bfgoodrich-all-terrain-t-a-ko2/p/29052
Its a 33" tire and no rubbing at full lock. And so far it handles pretty good, a lot better then the sr-a haven't hit mud yet just been driving in some pretty good rain. And it takes more throttle before it spins
Stock tire
8C716801-2860-4096-B520-34E71D6F464E_zps
New set
64161B7E-7851-457C-B63A-8418D353B81D_zps
My question is did i win or would i have liked the other brands better? I have nothing to compare them to
  • Replies 75
Looks good!
I opted for Goodyear Duratrac's on my truck. I love them, and have been great in the rain and snow as well. Plus they are quiet, but looks aggressive. There's definitely lots of good tires to choose from!
U can't go wrong with radial T/A's - Been around a long time....... As always with new tires - Take it easy for a couple hundred miles - let the mold release wear off.......
:driving:
I have KO2s on my sierra and really like them so far. I've had them 13k miles and seem to be wearing minimally, should last 40k I'd guess.
I have about 30k on mine and wearing great, awesome in snow. One of the best tires out there I think.
I've honestly had no complaints with my SR-A's. They've been fine in rain, snow, and on the beach. I wouldn't expect them to do well in mud but this truck won't be seeing mud so not an issue. I've got 30k on them so far and still probably have at least another 20k of tread left on them. Will probably be getting KO2's are Toyo RT's when these are done and I'll level it at the same time.
How many miles out of the SR-A's? What size new tires? They look very nice on those OEM wheels.
9k honestly they had life left but since i had a plug in my side wall on the back I decided that if i buy tires gonna buy the correct ones once..
Thank ya.
Mine did ok just lack of traction i did put mine in mud and it held up deffently not a great tire for any backroad use/mud.
I need to level mine out now.. make it complete i am surprised i can run a 33" tire i imagine it will rub if your full lock hitting bumps at speed? Its a tight fit at lock.
Bfg all terrains have been around a long time for a reason. What size did you go? Is your speedo off?
275/70/r18 i used my phone and never could get a good reading it showed 3mph + but went back down to 1+ mph.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
