Air filter
I'm not happy with the performance of my 2015 Silverado 5.3 V8 when I'm not pulling my pull behind trailer. I knew it could do better than it does now. I replaced the OEM filter with the open air, AFE dry filter and what a huge difference it makes. It sounds great and makes a big difference in torque. When I need to get on it the pickup was just not their and I knew it could be better. I also put on a dual exhaust and now it sounds like what an AMERICAN V8 should sound like!
I hope the moderators keep this somewhere we can find it and I'd like to see an informed discussion. Sound? Yes. Noticeable throttle response change? Skeptical.
How about MPG?
An air filter gives a fraction of a percent of hp/torque increase by itself on an otherwise stock setup. Most likely any difference felt is placebo. It does make a cool noise though.
My thought is you are moving twice as much air through the intake at 4,000 rpm so as 2,000 rpms. Therefore the filter isn't very restrictive at cruising speed, so it's a waste in my opinion. Gearing is what I'm guessing makes a difference. A lower gear puts the rpms higher, torque is increased in higher rpms. Once rolling down the road my truck is constantly trying to reduce rpms, at 45 mph it's trying to shift into 6th gear, I think that's ridiculous. I haven't pulled a load yet with my truck, so I can't say what Tow/haul will do, but I believe gearing makes the difference.
I'm very interested to see how this thread goes.
Keith
I read some very good advice from this website . When I made a comment about my air filter and the better performer that I got, I never claimed to be an engineer or a transmission expert! I was just trying to give some friendly advice. I feel like I'm on Facebook. Sorry if I offended you their will be no more comments so I can't be wrong anymore.
Did you get the complete system with new intake tube and air box, or did you just do the drop in filter? The aFe intake is considered to be the best and has proven itself in the real world and on the dyno!
High-flow filters and intake systems typically muffle induction sounds less than conventional paper filters do, which can give the impression of better performance — or simply a desired sound — that's worth the price of admission for some drivers.
I did put in a complete system, I noticed a difference after that. Now l put a dual exhaust on it. It's a dual exhaust after the catalytic converter, That gives me the good sound that I wanted.
did you have it on a dyno? Any improvement?
Almost 300 hp at the wheels, but that's after reprogramming the computer. The Dyno said 155 mph, but of course the Dyno is a lot higher than what I will get. After I drove on the highway I went 110 mph and I slowed down because of traffic. Before I could only go 99 mph. I was told it will go 130 mph, Will find out soon! The engine performs so much smoother. Before I did all of this The response was so much slower.
Google driveshaft failure. Happens at around 115mph give or take. Don't try the 130mph.
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
