Zachs_Alligator's 2017 Twin Turbo RCSB Silverado build
Wow. The works that goes into this is real dedication. Can't wait for some videos of this beast!
Thanks. Hoping to having it running this weekend. He's cutting the holes in my fenders tomorrow. It's what I want, but it still feels weird cutting up a brand new truck. When I do a build, I do a build, not just wheels and tires.
  • Replies 87
Ahhh gotcha. A supercharger will def fit then. Turbos can go anywhere if you have a good fabricator. I've had superchargers and turbos are leaps and bounds better in terms of reliability and power delivery if setup properly.
That completely depends on the vehicle. I've had both on every vehicle I've ever owned from my 10 second twin turbo grand national, pro charged 13 6.2 Sierra, 2000 turbo viper to my current low 10 second gt500. There is no way either are leaps and bounds better than the other. Each has their strengths and weaknesses.
Took a hole saw to my fenders:
Bezel Rings, black to match all the trim:
Overall View:
Turn up your speakers if you're on a desktop, sounds crazy good.
First Start up: I put a base map on it myself, sized the injectors, and thankfully it started right up. The extended cranking is from the lack of fuel in the system. The mechanical pump had to build pressure in the rails.
https://www.instagram.com/p/BVx03G_l5Sm/
Some turbo noise:
https://www.instagram.com/p/BVx-oPkFYT7/
With those exhausts coming out the fender + no cats .. she's going to be Loudddd !! lol I like it !! Worries about spot on the white truck at all ?
Oh yeah she sounds a tad like a tractor. However, as soon as you give it a little gas, all you hear are the turbos spinning up. People may mistake it for a dirtymax LOL.
Ha ha ha !! That's awesome !!!! I'll bet we see some flames @ night !
Holy F! This is impressive man.
Thanks!
My dad isn't really one for modifying any vehicles. So when I showed him the fender holes I got the same reaction except negative. HOLY F, YOU DID WHAT!?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
