On 11/30/2017 at 8:37 PM, rtreptow7 said:
So after messing around with this forever, I think I finally have it working.  I have a 2017 Denali HD that came with the wireless charger that wouldn't work with my iPhone 8.  I ordered the wireless charger module for a 2018 Denali HD part number 13521066 from needgmparts.com.  (On edit: I had to email the company as the part number was not listed or found in a search). It was 97.65 plus shipping. The new charger module has a different plug but uses the same 3 wires. I ordered the new plug from Mouser electronics part number 571-2035363-4 . It cost 71 cents.  I easily unpinned the old connector.  When installing the new connector, the pins on the wires had a little "nub" sticking out on one side that wouldn't allow me to slide it into the new connector.  I took a small pliers and just squeezed these "nubs" down so they were flush.  The pins then slid in easily and clicked in place securely. Plugged the new wireless module in and put the lid for the center console back together and it seems to be working the way it should now.  Little green lightning bolt shows up on the screen when phone is on the charge pad.  I can pick the phone up, set it back down and it starts charging again immediately.   Thanks to all the users on here for the information they provided regarding the parts, connectors, correct part numbers, etc.
new module below
Here is the FCC filing information for this module, including a user manual and photographs of the inside:
https://fccid.io/BEJWC900A05
new module below
Thank you for posting this.
Thanks to everyone and rtreptow7 for doing the research and legwork on getting the part numbers for the new 2018 charging module and the associated connector part with Mouser.
I finally got my module today, and will include some additional pictures to complement the ones rtreptow7 posted.
Box of the module, and the module itself:
Here is the connector from Mouser,  571-2035363-4 , for the new unit.  This is needed for the new charging module.  The old plug will not fit at all into the new module, so this new connector is needed.  When it arrives from Mouser, all the pieces are attached.  I personally found it easier installing the wires into the new connector with the big red piece off the end removed.  To do that, simply use a small flathead screwdriver and carefully pry up the sides.  It will come right off.
Edited by Bangback
The old connector is shown here, which is white with a red component.  First note the color of the wires and which slots they are in.  Don't pay attention to the bars on the connector.  They are on different sides from the old connector to the new connector, and they will just confuse you.  Just pay attention to where the push lever is on top of the connector and note that the wires are in the left 3 holes.  They will go in the same left three holes on the new connector, with the push lever on top.
First thing you will want to do is to remove the red plastic piece.  I used a small flathead precision screwdriver.  Just push on the middle red tab and push it outward.  It will take some force, but the piece should slowly slide out, as seen in the pictures below.
Make sure your ignition is off as well as the radio.  Once the red piece is off,  look deep within the connector and you will see white tabs over the tops of the metal pins, from looking into the end of the plug where the charging module pins plug in.  Gently take your precision flathead screwdriver and lift up a little bit on the white tab.  The wire should now easily pull out from the back of the connector.  It shouldn't take too much force.  If it doesn't easily come out, you may not have the white tab lifted high enough.  NOTE when you remove the wire, remember how the metal crimp pin is oriented in the old plug.  You will be plugging into the new connector with this same orientation.  Also try not to touch the wires together and short anything out, just in case there is power.  Temporarily taping them apart so they don't touch isn't a bad idea.
You will then see the "nub" on the metal piece that rtreptow7 referred to earlier.  It is shown in the picture below of the metal crimp pin, on the top side.  This needs to be compressed a little bit with pliers or use your flathead screwdriver to press in the nub.  If you don't press this in, it will be very difficult to slide the metal piece into the new plug.  The picture shown of the metal crimped wire is the correct orientation as if you are looking straight down from the top of the connector.  This "nub" will look like it's on the right side of the pin when placed into the new connector.
Again, on the new connector, I entirely removed the red end piece for installation.  Just lift the sides of the red piece with the screwdriver and it will pop right off.
After you press in the "nub" on metal crimp pin, just slide it in, and listen for an audible "click".  Check the end of the connector and you should see the metal pin go all the way to the back of the new plug.  Do this for all 3 wires, make sure you have the colors in the right spots, then put the red piece back on the end.
The new module is an exact fit to where the old module is.  It bolts right on with the same screws.  Plug your new connector in and test.  It should now work!  Good luck!
Edited by Bangback
Great work @Bangback
I skimmed through this thread -- has anyone confirmed whether or not this allows for "fast charging" ??? If it does, I'm in!
40 minutes ago, rcpd34 said:
Do you know the difference between your new one and 13507652?
User Pgamboa has some great pictures in this thread at the end....
Someone posted part # 13507652, but no one seemed to have a pic of it. That’s when the actual module part # 13521066 started to surface.
I don’t have a pic of 13507652. The bottom two modules here are the same.
Well, I ordered it as well as the Mouser plug.  Hopefully, it's the correct one.  I got the number from my dealer which he said was the correct part number for the 2018.  I guess we will see...
Good to know that the new design has 3 coils!  That should make it less critical as to where to place the phone for the optimal charging position.
I haven't done any testing  yet with charge times with the new charger.  I do have the latest version of iOS on the iPhone X, which should have 7.5W wireless charging enabled.  I could try to capture some charging times, but won't know for sure what the actual voltage and wattage coming in is.  In about 10 minutes or less on a short drive I took, the phone went from 70% to 73%, from what I've seen so far.
Edited by Bangback
I sent an email inquiry to GM Parts Xperts, the company I ordered module 13507652 from, and this is their reply cut and pasted:
The part number that you order changes to part number 13521066, they are the same part.
Hopefully we are all good.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
