On ‎3‎/‎2‎/‎2018 at 12:08 PM, 2017SierraSLT said:
No. GM's parts system lists the "big chin" mat for 2018. Obviously, this is not correct! I said screw it, and made my own from two big chin mats. Looks OEM.
On ‎3‎/‎2‎/‎2018 at 12:15 PM, zikronix said:
where did you cut the mat to do it. Need some details on this!. Also that brushed looks good and matches the axiom finish in my sierra. I aint paying 50.00 for it tho...LOL to hell with that!
I was just told from my parts guy that the 2018 charging mat P/N is 84199943.  The previous charging mat is 23264395.  The new mat is VERY expensive compared to the previous mat.  The new mat lists for $103.52 and previous mat lists for $9.55.  Gmpartsdirect.com has the new mat $67.08 and the old mat at $6.19.  I ended up ordering one to see why it's so expensive so we will see.
Edited by BlkSS
Holy moly! It’s gotta be the extra ridge. LOL. Let us know.
Got a 2018 Suburban without Wireless charging. They don't offer it as an option or accessory from parts.  So I took apart the center console and it seems that in order to add the GM version, you need to replace a harness that runs from the front from a BCM presumably all the way to the back in order to have the port to plug the harness from the wireless charger into.  Parts guy saw there were two harnesses but couldn't confirm if that would be enough to solve for the problem.  Then I also remembered the 2018 I rented over the holidays was a bit finicky with the placement of my iPhone X.  So I looked for aftermarket.  So for those without wireless charging now or even those looking to upgrade your charging to work with iPhone X or 8, here is an other option: Brandmotion 1273
It took me about an hour to install.  Probably not even.  It was really easy.  Tapped into power at the BCM under the steering wheel.  I did make some wiring modifications compared to their instructions to avoid drilling holes they wanted drilled.  But this thing works flawlessly! And I like the Blue light that turns green when the phone is charging.  Instant visual feedback.  I have not had any issues with it keeping the phone charging.
Just thought I'd share another option for those of you looking.  I was hoping to replicate the OEM set up, but between the growing cost, the possible roadblocks and the potential for it to be a bit touchy, I settled for this option, and I recommend it highly.
I spent the better part of a week outfitting my 2017 GMC Canyon Denali with the 2018 GM #13521066 charger. Phil (pgamboa) went cruising and his harness parts went on back order so I obtained the plug and connected it myself. Pretty green light illuminated when charging. I want to thank Phil publically for his communication and skills in the charger conversion as he is an asset to this forum. Yesterday, I traded the 2017 GMC Canyon Denali in on a 2018 GMC Sierra Denali which has the larger charging pad and Qi. Now, can you believe that? What the?
zoz
14 minutes ago, MRL_Sierra16 said:
Did you take the 18 charger out and replace it with the original in case you need it later?
No. It wasn't worth my time as mine is now under warranty.
zoz
I got my plug a few days ago and the charger today. Installed in less than 15 min. Everything works great!
14 hours ago, Loco-diablo said:
How’s the charge speed? Is it as fast as the wired charge?
Not nearly as fast as a wired charger.  My rate is around 10-12% per hour.
Received my module plus new connector.  Of all the bad luck one of the pins broke and now I have to figure out where and how to get a crimp female connector for 22awg.  No Radio Shacks available any more.  Anyone have a suggestion how to get a couple of the connector pins?
Mouser Electric has the red plug connector and the pins. The red plug is 571-2035363-4. The pins are 571-1924955-1.
zoz
Just received my 571-2035363-4 from mouser. Re-pinned from the old plug and voila! I literally watched a 2 min video on how to re-pin on YouTube and I figured it out. So easy!
Well, I'm having the same problem as everyone else. I took my truck in for scheduled service and had them check the charging pad and it has power to it but it wouldn't charge either my phone or anyone elses doing the service work. Then we checked in an 2018 and my phone and the service persons charged just fine in that. They said it was because I have the Samsung Galaxy S8 Plus that isn't compatible as they gave me that list  that they have put out for everyone. Its never worked since I bought the truck late last year.
Ok, what do I need to do for my charging pad to work?
Swap it out for the 2018 module. Part # 13521066. You’ll either need to repin the connector since it won’t fit the new module or order my Retrofit Harness for $25.
    JimmyB4
    JimmyB4
  • Who's Online   3 Members, 0 Anonymous, 644 Guests (See full list)
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
