Towing milage
First day headed back north, averaged 13.5mpg towing 9000# best ever :)
Very nice - rarely did I get that towing with the Duramax even......... All hail the 6.2L Superman of engines.....
How?! I usually average 9-10mpg with my 7500lb camper (I also am 2.5" leveled with 33" duratracs)
I averaged 12.5 towing from central Indiana to Baltimore with a livestock trailer at ~6,000 lbs. Pulled like a dream even over the Appalachians.
Pretty stock 5.3, 3.08 4x4 LTZ crew cab. I did add airbags to help level the back end.
towing mileage depends as much on the aerodynamics of your trailer as it does the weight. Pull a 7' tall square enclosed trailer empty on the interstate and you will get worse MPG than a flatbed with 6,000 lbs on it (that is a guess, i have no proof)
once you get your truck up to freeway speed, you are really just fighting gravity going up hills, and air resistance.
Powerhaulic's camper looks to have a very nice rounded front end, which surely helps.
Various campers hundreds of thousands of miles, towing with 2010 diesel. Typical economy is 11mpg at 60 mph, 10 mpg at 65 mph.
Winds can skew that number over +/- 3mpg.
Aero is huge, as noted we have wind slick trailer.
Have also towed my open car trailer loaded with 5000#,about 3-4mpg better.
Tuesdays journey was south Carolina up I77 thru Virginia and West Virginia, heavy winds and lots of mountains. Averaged 12.1 with 5-7% grades, I am amazed !! Running at 62-68 mph is ideal
Nice trailer and it's slick as a button to ha ha... That helps.
Mines older school and catches more wind.... but still does better then the ones with the flat fronts.
11844952_10152856498151525_6004298225179
Our camper also has a concave rear to break the suction, it tows really well.
As I said 12.1 yesterday in the mountains of WV, in heavy winds i'm thrilled.
Today we will head thru western PA into NY and across NY, stopping in Rochester to visit friends.
Only issues have been another trailer tire failure, going to be a new set if E rated tires installed when we get home.....
you cant beat that mpg!!
This is what I get with my 33" Duratracs and 5.3...
Sent from my Nexus 6 using Tapatalk
That's what I get with an unladen landscapers trailer, 5x10. 650 lb dead weight. My little S15 with a 2.8 V6 does 4 mpg better with the same trailer.
I tow an a frame camping trailer which had awesome aerodynamics. I have a shell on my truck do the top of the trailer is just below the shell. Only lost about 2 mpg when towing. Averaged 16 mpg towing through the hills of socal in the wind.
Sent from my SM-G900V using Tapatalk
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
