Condenser ordered for my 14 as well. A/C started blowing cool then warm air about 3 weeks ago. I read the stuff here and figured I had a faulty condenser. Finally got it in the dealer today and they confirmed my suspicion. Anyway, supposedly new part will be in by the end of next week. I'm not holding my breath. But thankfully we are getting a reprieve from the heat here. My extended warranty will cover the repair 100%. Now I wait....
Got a call yesterday from the dealership where my truck has been sitting for a month. Was informed that some condensers had come in and my truck would be ready Friday (tomorrow). So, guess suppliers are starting to catchup on backlog.
It's in. Took about an hour and a half. Pulled a vacuum and it stayed for an hour so I charged it. Hopefully it'll stay that way. $300 in parts and some time is way better then the dealer quote. Granted I'm out of the bumper to bumper warranty otherwise it would've been on GM.
Add me to the list.
2014 GMC Sierra. My AC went out in early June. Condenser was leaking. After refilling fluid 3 times I finally decided to have it repaired. I called several dealers and/or repair shops and each person I spoke with told me this issue has become an epidemic. However, GMC/Chevrolet have yet to step up to the plate and cover the cost of replacement.
The cheapest quote I got was $850 from Kwik Kar. Dealerships want anywhere between $900 and $1200.
Also, the condensers are on back-order for up to 6 weeks because GMC had to make improvements to the existing design and ramp production of replacement condensers.
So if a design is flawed and causing widespread failure, why wouldn't this be covered by the manufacturer?
I found a off-brand condenser through Amazon for $120. However, after talking with one of the mechanics about this, he said it would wind up failing, so it would be better to wait for the "improved" condensers coming from GMC directly.
So here I am two months later driving around in Texas summer heat with no AC.
Has anyone heard of GMC changing their position on covering the cost of repairs?
Out of the $950 it cost me to replace my condenser at the dealer, GM paid all but $400 for my out of warrantied 2014. I reached out to them via chatting on the GM website. They called me back and worked out a deal with my dealership. Dealer and rep from GM recommended that I keep my receipts for a refund of what I paid if they do a recall.
Well, appears GM has a new problem; heard on the news last night that GM has a recall out on 2014 Silverados and Sierras for electronic power steering failures. Said the fix is a reprogram. I know, I'm off-topic but thought I'd share anyway .
The GM dealers around me are buying up all of the aftermarket ones as the factory still has not been able to supply enough to support the failures..I've replaced a few out of warranty ones at my shop but mine so far has not shown any signs of leaking. Fingers crossed.
After a month's wait at my dealership, I had mine installed last week, works great. I forgot to ask what specifically was done to make the replacement condenser more robust though. Anybody know?
Truck goes in Thursday for condenser replacement. Fingers crossed for cool air. It has gotten really old running with the windows down in this heat/humidity.
    • Couple plausibilities.   - Bent pushrod   - Bad injector   - Roller lifter failed and has been eating the cam lobe(s).     - Broken valve spring   All are options.  Most common that I can recall would be the valve spring (hard to see the break on it as well), the cam/lifter and the injector.
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
