Paintor Posted November 27, 2017 Posted November 27, 2017 2016 Sierra 5.3 doesnt like the cold weather and takes quite a bit longer to crank over and start in the mornings when it is cold. Has anyone tried synthetic Slick50 to see if it leaves some lube on the engine parts to help cold weather cranking? With this Zero weight motor oil....just curious if it will help prevent wear with cold starts?
Black02Silverado Posted November 27, 2017 Posted November 27, 2017 I would not put anything in the oil other than a good quality oil, synthetic is even better. It is a waste of money and GM does not recommend it. Neither does AMSOIL. If you use a quality synthetic in the proper weight, ie, 0w-20 you will get all the protection you will need.
O_J_Simpson Posted November 27, 2017 Posted November 27, 2017 Combine it with a intake Tornado for maximum results.
KARNUT Posted November 27, 2017 Posted November 27, 2017 It was very popular before synthetics, just like STP. Sent from my iPhone using Tapatalk
JoBo1943 Posted November 28, 2017 Posted November 28, 2017 My 2017 GMC 5.3L at 4k miles rattles for a second when started cold. That can't be doing the engine any good.
Black02Silverado Posted November 28, 2017 Posted November 28, 2017 2 hours ago, JoBo1943 said: My 2017 GMC 5.3L at 4k miles rattles for a second when started cold. That can't be doing the engine any good. What oil and filter are you using?
JoBo1943 Posted November 28, 2017 Posted November 28, 2017 At only 4,444 miles today it still has the original factory fill of 0w20 The oil level has not gone down. After the first two free changes I might entertain switching to something a little heavier or an additive My daughter in laws Honda Pilot that havs variable timing and cylinder deactivation calls for 0w20 and my son started using 5w30 with good results.
Paintor Posted November 28, 2017 Author Posted November 28, 2017 Bit more research and it appears Slick50 no longer offers its engine warranty...since 2013.
joshc64311 Posted November 28, 2017 Posted November 28, 2017 Don't listen to what engineer's recomend, Just run 20w50 you'll be fine
MaverickZ71 Posted November 28, 2017 Posted November 28, 2017 19 hours ago, Paintor said: 2016 Sierra 5.3 doesnt like the cold weather and takes quite a bit longer to crank over and start in the mornings when it is cold. Has anyone tried synthetic Slick50 to see if it leaves some lube on the engine parts to help cold weather cranking? With this Zero weight motor oil....just curious if it will help prevent wear with cold starts? Direct injection engines have been known to take a tick longer to start than the previous generations. Is your battery in good shape? Are you using Top Tier fuel of the proper octane rating or above? Over the years, I have tried all of those additives like Slick 50, Prolong, Restore, ZMax, etc., and didn't notice that any of them made one bit of difference, except each time my wallet was a little lighter. Now I am older and hopefully a little wiser and don't spend my hard-earned $ on that snake oil crap. But I do use Chevron Techron Fuel System (not Fuel Injector) cleaner at each oil change as recommended by GM (it is the same as GM fuel system cleaner), because some of the gas stations around here are apparently selling scummy pond water laced with moonshine and marking it as 87 octane fuel.
Paintor Posted November 28, 2017 Author Posted November 28, 2017 AutoZone had it on clearance. Poured half the bottle in the motor....will see if it starts any easier in the morning.....after a full night of freezing temperatures.
gone_fishing Posted November 30, 2017 Posted November 30, 2017 More information on the extended crank times: http://sandyblogs.com/techlink/?p=2971
Paintor Posted November 30, 2017 Author Posted November 30, 2017 3 hours ago, gone_fishing said: More information on the extended crank times: http://sandyblogs.com/techlink/?p=2971 Hahaha. 3 seconds of crank time is acceptable?....this morning was too warm...waiting for a freezing night again here to see if Slick50 helps in cold starts
