Vent visors
rogerdoger
So I just purchased my first brand new truck last week. 2017 Sierra 1500 and I would like to get some feedback for vent visors so I can roll my windows down a bit when its raining. What are the pros or cons between the in-channel ones vs the tape on ones? I was thinking the in-channel would be better seeing I dont have to deal with the tape. Just wanted to see what folks here had to say
https://www.realtruck.com/avs-in-channel-vent-visors/R18883P2017Y856MA.html
https://www.realtruck.com/avs-tape-on-vent-visors/R18906P2017Y856MA.html
I recently went with the AVS low profile tape on one. I like the flat look of the low profile ones vs the in channel bubble looking type ones. No worries about window interference.
I have the AVS in channel ones and love them  Not one issue with window interference. I think they have a "cleaner" look than the tape on ones. Just my $.02.
I’m torn on the in channel and the stick on low profile visors. Low pro visors look hella clean and smooth imo. But the in channel ones look less “cheap” imo.
I've had both and the in channel ones from Weathertech were the best yet.
14 hours ago, duquephart said:
If you like wind noise in-channel will do it for you.
In channel does give you some noise and for me it messes with my auto up feature, sometimes it stays up sometimes it rolls back down. It rolls back down bout 70% of the time. Folk say I need to do a window relearn but I’m too lazy to do it. In channel does look the best without messing with your paint.
I agree with messing with the paint and that had me concerned. Then I said screw it, there are a lot worse things to worry about with the paint than 3M tape.
My last truck had the smoke colored in channel ones, and I liked them, but they were bubble shaped. That truck had manual crank windows, so interference wasn't an issue.  My buddy has the low profile tape ons on his 2017 Denali HD. I liked the look, so that's what I ended up with. No regrets.
I have the in channel on my 16 CC and really like the looks but I do get the auto up interference and I can notice the cab is louder with them installed. I bought the ones from GM when I bought the truck and have taken it back for the issues and they have told me there is nothing they can do. I've tried the relearn but all it seems to do is leave the window slightly cracked. With that I do still have them on the truck and don't plan to take them off unless something happens. Personally I didn't want the stick on ones because I didn't want anything on the paint after dealing with my 15 and bad paint and a buy back from GM.
I had the AVS in channel on my last truck and they interfered with the auto up almost every time.   I also am convinced they do cause some wind noise.
Ive had WeatherTech on another truck with no interference, but...wind noise.
i just bought an ‘18 and suspect I’ll skip them this time.  At least until summer...
    • Boy do they have some margins in that to come down $5000!!!!!   Does it change my thoughts?  Not really.  That's only one thing addressed.  The transmission.  Still needs an oil pump belt if that hasn't been done yet either, which per the Carfax, looks like no.    And then still, timing chain because 2020.
    • I like things to be more nailed down. For instance. People ask why my father left a multi million dollar business in NJ in the seventies and started over in Texas. The answer is simple, payola, threats and quality of life. He didn’t like the game. And he didn’t want his kids to be wrapped up in that mess. That’s nailed down no guessing.
    • So any kind of deviation is not permitted. Even if it manages to touch on Oils Chain intervals only if, it addresses your latest threat. Boring.😴
    • The tailgate of pickups is not designed to be water tight. There are seal kits for them but I doubt they work effectively. But, I've not tried them. I always have hard folding tonneau covers and the BakFlip brand has been my favorite. And, for the most part, the bed stays dry. I would invest in some bins that can be closed to better protect sensitive stuff.
    • A properly installed tonneau will keep out 95% of the water.  As others have said, the only way to be completely dry is to either get a topper or an SUV.   I've run virtually all the trifolds and hard rolling that are out there.  My thoughts:   1.)  The leak points of any cover will be the front corners, and around the tailgate.   They will also leak if the rails are not installed properly.  If you take a electric/cordless ratchet and snug down the clamps, you run the risk of overtightening which causes the rails to sag.  When the rails sag it creates a gap between the rail and the bed cap and this lets water in.   2.)  Different manufacturers use different methods to try and seal the front.  The "driest" setup is probably the Leer HF650M, which uses double seals all the way around and doesn't require a foam seal across the front edge of the bed.  The Realtruck trifold covers (Bak, Undercover, Gator, etc...) all use a foam seal across the front, and drain tubes.   3.)  Realtruck has standardized the way that the cover attaches to the rail.  With the exception of the Extang Endure ALX, all other Realtruck covers use a plastic clamp which slides into a channel, hooks onto the edge of the rail, and tightens down. The "Realtruck Advantage" covers sold by GM dealers as an OEM accessory still use the "bolt through the panel" installation method.  Problem with these is over time, water gets past the rubber seal, into the panel, and once they become waterlogged they begin to delaminate (and weigh a ton.)   4.)  Unless you are using GM Rewards points, buy your cover separately.  Realtruck offers a 5 year warranty on BAK, Undercover and Extang covers.  Gators get either a 2 or 3 year warranty.  If you have an issue, they are much easier to deal with.  If you have an issue with an OEM GM cover, you have to go through the service department and GM Warranty processes to get it taken care of.   Recommendations based on my experience:   Hard folding:   1.)  Undercover Ultra/Armor Flex (identical except Ultra has carpet on the underside and a smooth finish.  Armor has no carpet but has a Line-X coating on the outside.) 2.)  Leer HF650M.  Has 4 panels instead of 3.  Double seals to keep the water out.  Downside is only a 3 year warranty and warranty only honored if you purchase from a Leer dealer.  If you have your dealer install it or buy off Amazon they won't warranty it. 3.)  Bak MX4.  They sell a ton of them.  A good cover for the money when you can find one on sale.  About to be redesigned to include a spring to ease opening and closing. (Supposed to be released 7/26.  Bak MX4 EZ-Lift)   Hard rolling:   Bak Revolver X4S or X4TS (has t-slot rails.)  Personal favorite and the one I use on my truck.  Easy to roll up one handed.  Doesn't block the rear window.  Only costs you about 6" of the bed when open as opposed to a retractable canister which eats up about a foot of bedspace.  Downside is it's either all the way open or all the way closed.   Good luck with you search.
