Update, I received the Echomaster Intellahaul front camera system.  Extremely easy install.  Just watch the videos on Youtube by Echomaster.  The hardest part was going through the firewall.  There is a rubber grommet, where the main wiring harness goes through, but there seems to be multiple layers to it and under the dash you can't seem to get your hand through all the mechanicals to even get to the grommet.  In about an hour or so it was complete.  The instructions state to put the camera right under the bowtie but I chose to go lower after what Jmiller11331 recommended.  All in all I am very happy with the result.
What part number did you go with? I’m only seeing options for the 2018, but i figure it will probably work on my 2015 Sierra. Thanks.
I bought the Single Front Camera System for $399.   I have a 2017 and yes, I also bought the 2018.
Part # 19366657
Hope this helps!
I used the backup camera for my Garmin and mounted it above the M in the grille of my 17 GMC. You have to look really hard to see it. Instead of using a switch, I wired it so that it changes from GPS to front camera whenever I press on the brakes. Real handy when I am parking close to anything in front of me.
Great idea.  Backup camera kits often come on sale for less than $100 at my local auto store and I often wondered if these would work well as a front camera.  They don't advertise these products as having the option of being used up front but I don't see why not.  Of course they wont be integrated with your dash display but an additional small screen dedicated to this purpose would look fine when considering the money saved!
I’m very interested in this product. I don’t quite have a feel for the front end yet, so this would be nice for parking in tight spots.  A couple of questions. Have there been any issues for anyone that has had them installed for a while?  Did anyone route the wire someplace other than that big rubber plug? I don’t really want to cut that. Ty
Donstar. Did you go with the intellihaul camera, and how do you like it? Where did you route the camera wire? Ty
Edited by Jchoi
I installed an aftermarket Pioneer radio and slapped a camera under the transmission looking forward.  My wife's not very good at spotting while offroad so this turned out really well.  I can see where my tires are in relation to the trail.  I can't remember which camera I bought but it wasnt very expensive.
I am considering doing this mod, once you get cable through the firewall, do you have to take the dash apart to connect this camera to the infotainment center? It would be nice to have this camera especially when parking and can't quite get an idea how much clearance you have in front of you.
Was pretty easy.  Hardest part was running the camera wire through the firewall.  You dont have to add power or anything as it hooks up to the factory radio and works from there.  Comes with everything you need to install.
How much of the dash did you have to take apart or was it just the bezel around the radio to get the cable harness through to connect to the infotainment radio?
Here are the instructions:  https://echomaster.com/index.php?controller=attachment&id_attachment=1438
Yes just the radio bezel area and you have to plug in a wire at the MVI behind the glovebox.  I did not remove my grill as I just ran the wire and mounted the camera at the M in GMC.  I have a Denali grill.  If you can do any basic work its easy.  I am not a mechanic by any means but I will try a DIY project here and there.
Thanks for the instructions. Doesn’t seem to difficult. Going to order it today.
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
