Chevy Shake has Competition
Saw this the other day when studying the solution to the problem. Looks like GM is not the only ones trying to get out of fixing shaking trucks. However this makes the Shakerados look like 80's Caddies. Maybe switching to Ford is not the answer after all! I am aware it is a SD and probably has some straight axle death wobble, but it is still fun to know we aren't alone.
A guy at work had the death wobble on his 2017 Super Duty at 15k miles. The dealer tried tires and alignment with no improvement. An updated steering stabilizer seems to have fixed it. They had his truck for 5 or 6 weeks.
My boyfriend has been experiencing this same issue on his 2015 GMC Sierra and had to take it in to the dealer as well as several certified service shops and still, no answers and no fix!
We're trying to collect information on the issue and started a survey to understand why the dealer hasn't been able to detect this issue and fix it sooner. If you'd like to take part in it, we'd love your feedback on the issue too: http://bit.ly/gmshake
Nice dealer says Its a truck you know ........operating as designed .......Tech can not pull up any codes or replicate in test drive !!!! Dealer offers him a free wash and sends him ''on his way''. lol
This is common problem that afflicts some GMC and Chevy trucks. The issues are well documented on this and other forums. Some folks have been able to rectify the problem while others haven’t.
i am not a sue happy person but if it was me i would be talking to a lawyer, not designed to go over 65 BS
 Just a thought - Seems that video is showing more than an unbalance shake. Had many vehicles with unbalanced tires , fronts usually cause more of an up-down vibration without excessive steering wheel play, rears less and definitely in the 50 - 65 mph range but that back and forth play in the steering wheel seems to indicate something more  - either the driver is driving looking at the front of the hood instead of aiming high on the road ahead for road centralization......or much more likely rear axle bounce and tires are loosing lateral contact with the road. If equipped with the trailering package, there is anti-sway control built into the vehicle software which could be false triggered by intermittent rear wheel operation.
I remember posts around the time I purchased my '16Z71 new and it was equipped with different GM number rear leaf springs than previous models, I believe there were also aluminum vs. steel control arm differences.  Over 12K miles and still running smooth as silk - and I never rotate the tires (not even under the free 2 year maintenance) so long nothing vibrates and they are wearing evenly
OP should load the bed with over 500 lbs of crap over the rear axle and check operation to see if it reduces vibration.  Dealer's max 65 mph claim is B$, but vibrations maybe caused or aggravated by running with an empty bed. Could be the extra wide trailer towing option in the video comes in an OEM package that triggers a spring change that assumes max load causing an axle hop with an empty bed.??? Not making excuses for GM.....it's F'd up either way.....but if loading the bed reduces or eliminates the vibration, a rear spring change may compensate.
Well it seems youtube has several videos of Fords and the shakes. This one looks like a paint shaker at Home Depot...
I’ve seen several threads on this and the video isnot working. Argh!
That is pretty dang scary. A buddy's jeep used to do that. Seems he put a steering stabilizer on it to calm it down. The jeep was far from new and had seen a lot of rough use.
    Afennell19
    Afennell19
  • Who's Online   4 Members, 0 Anonymous, 857 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
