Rain &4wd
MY164X4
There is still something not quite right with this truck compared to other makes and GM's of the past.  As I mentioned above I have driven only trucks my whole life and I take a company truck home for the past 25 years where I get a new one every three years or so.  I have never had a truck behave as bad as my 14 when it comes to wet roads not matter how lightly I feather the throttle.  I also disagree with those who say running LT AT tires is the cause for some of the slipping.  My personal trucks and all of my 8 or so work trucks over the years all had LT AT tires (except my 14 because still on factory SRA's) and I have never had a problem with any of those trucks getting loose unless I purposely made the rear end break loose.  I still think we got a nice powerful engine with a not so great transmission causing a lot of these problems.
  • Replies 35
I must be doing it wrong...I rarely need 4wd in snow and ice and never in rain or wet roads.
Sent from my SM-G950U using Tapatalk
The Goodyear Quadrtecs are awesome!   Almost never put in 4.   Wet roads are nothing for these tires.
I don't use 4 auto as I had the converter fry on my '14.   It is my understanding the clutch system on the '15 and newer are much better.   4 auto should do the trick for you.
Need some advice today I have a 65 mile trip to Nashville tn, and it is raining all day, is it safe to drive in 4wd?
And if so high or low, this is my first 4wd.
I have BFG K02 LT.
And these ****in tires slides in the rain.
Sent from my SM-J727V using Tapatalk
I’ve been driving here in New England since 1976! The only time I use 4wdH or AUTO, is in the snow. If it’s not snowing or snow covered roads, I always drive in 2wd
So all seasons tires is the way to go?
Check out the Michelin Defenders, they’re not All Terrain but in all seriousness, they’re awesome all around Tires that blow away any all terrain tire in dry and wet road conditions.
Will do thanks for the info.
Put a set on my wife’s Yukon and on my Sierra CrewCab 4x4 Z71 and have noticed only one thing, Outstanding results!
Click on the pics, blow them up and checkout the sipes on these tires, the sipes run straight down all the tire. Yesterday, I saw a truck with BFG’s KO2’s on it and sipes were missing even though the tires still had lots of rubber on them. Good luck and I hope I’ve helped you with your choosing the right tire for your type of driving.
I have driven pick ups my whole life, all of them 2 wheel drive until I bought my latest truck an never had any issues in rain . I have these tires on my present truck, no problems with rain . Only put it in 4 wheel drive once this year when I was busting long 1 1/2 foot deep snow in a driveway this year
Thanks u can't go wrong with Michelin.
I have to see if I can fit them in my budget.
I give all 3 of my cars a $800.00 budget
when it comes to tires.
Totally understand but never go cheap when you’re riding on safety, good luck, God Bless
Thank you for the kind words Sir.
+1 for Michelin.  If your slipping in the rain, tires are the culprit.  Don't use 4 wd to compensate for poor tires.
The Defenders sucked on my 2500.  Maybe they do better on the 1500 but I won't buy them again.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
