2019 vs 2015-2018 8 speed
I saw in the GM newsroom that the 8 speed and 10 speed automatics both received updates to improve shift quality. I wonder if it is physical or software. As far as the 8 speed goes I wonder if anything will apply to 2015-2018 8 speeds. My 2017 has 16000 miles on it and finally shifts normally about 90% of the time. Still feel a bump downshifting into 1st occasionally and occasionally a rough shift from 1st to 2nd if I let off the gas before it shifts. I figured out how to keep the upshift from happening but haven't figured out the downshift. I'm convinced it will do it forever but then again it's never not done what it's supposed to do and I've never had the vibration issues. Anyways a backwards compatible software update other than "relearn" would pretty outstanding.
  • 4 weeks later...
Different 8-speed TC and updates to the valvebody separator plate for sure. I really really hope they put a trans fluid dipstick on the 2019 8-speed but I'm sure thats not going to happen...
I'm hoping that GM made some refinements for the 8-speed. While I haven't been in an 8-speed truck that exhibited the behaviors many people complain about,  have read about them and it makes me a tiny bit apprehensive about the 8-speed. The gear ratios in the transmission are great and would be a huge changed for me but I don't want to deal with TCC shudder and odd shifting behaviors.
While researching a 2019 half-ton pickup truck for purchase, which transmission has a more robust design: Ram’s new 8-speed or Ford’s and GM’s joint design of the 10-speed automatic? This is a very interesting question that comes to us from Jason V.
I would say the 10sp since it will be bolted up to the 6.2 and 3.0 diesel.
Also I believe they "GM" have installed that German Centrifugal Do-Dad in all the 8speeds.  So after driving mine now if GM can "Dial" in the 8speeds I am perfectly content with 8 and to be honest the whole 10 speed thing seems like more trouble than what it's worth?
I’m no expert but it seems that if you can stay in the max TQ range adding more gears in that range could be a waste. I recently read a test in car and driver can’t remember the car mustang I believe. The ten speed slowed down the car slightly did raise the gas mileage a-bit. Makes sense if you’re interrupting engine pull for a shift.
Oops it was the 2018 Yukon Denali not the Mustang
  • 1 month later...
I have an 18 6.2 and 8 speed.  I don't want to jinx it but it shifts awesome. Great upshifts at most any speed and goes to seemingly correct gear quickly on light acceleration.   I often wonder if the updated tcm on 17 and newer allows for better/complex programming and in turn better drivability.  Why is the 8 speed in the new ZR1 and not the 10 speed?
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
