  • Replies 3.3k
Top Posters In This Topic
Earlier this morning my wife asked, "Can you please go to the store and buy a carton of milk and if they have eggs, get six.
I did as she asked, I returned home a short while later with six cartons of milk.
She said, "Why in the hell did you buy six cartons of milk?
I said, "They had eggs."
Now I'm in trouble.
  • Haha 1
An explosion last week killed a wild-living navy boiler man, and he found himself in hell...
Being used to stoking fires, and extremely hot temperatures, he found hell actually quite comfortable.
When Satan went to check out the new arrival, he found him sitting in his room smiling...
"You like this?" Satan asked.
"Yes sir," said the sailor, "this feels like a spring day to me."
Not wanting the new guy to be too comfortable, Satan turned up the heat a bit.
When he went back the next day to see how his new arrival was doing, the sailor was still happy...
He hadn't even broken a sweat!
"I like this kind of weather," he told Satan.
For the next few days, Satan turned up the heat more and more, but each day the Sailor looked as comfortable as ever.
By Sunday, Satan decided to try something different...
Rather than turn up the heat even more, he turned it off, and turned on the air conditioning.
Icicles formed in the sailor's room!
When he checked on the guy, the room was icy and he was shivering, but he had a grin from ear to ear, bigger than ever!
Satan was exasperated!
"Why are YOU so happy?" he demanded from the sailor.
"It's FREEZING in here!"
"Well, I'm from Dallas" said the sailor...
"And evidently the Cowboys just won the Super Bowl!"
  • Haha 1
I recently visited the Canary Islands.
Turns out, there are no canaries on the Canary Islands.
Same as with the Virgin Islands.
No canaries there either.
Edited by MaverickZ71
  • Haha 2
Last night around bedtime my wife's phone rang.
I answered it, then said, "I believe you have the wrong number. You'll need to call the weather number for that information."
My wife said, "Who was that?"
I said, "Some guy wanting to know if the coast was clear."
  • Haha 1
54 minutes ago, MaverickZ71 said:
Especially with the headlight dimmer switch on the floor below the emergency brake.
If it's on the tree it's where I started 😉
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
