58 minutes ago, starman8tdc said:
Do you know if your engine has direct injection or port injection? If its direct injection, then the install time would be a bit longer, but still - the bill is extremely high. Your right, the dealership charges a lot. I'm glad to hear that you didn't have to pay for it.
It is direct injection
57 minutes ago, cpttimerestraint said:
$1,800 is the going price by the time you get 8 injectors, all the extra seals and gaskets required and the labor to really it all apart.
Sent from my Moto G (5) Plus using Tapatalk
But you have r&r injectors twice. Plus diag twice.
So we picked up the car on Friday.
I was told that the fuel injectors they installed was bad out of the box. All the talk about carbon on cylinders and blah blah blah was just that imo.
They “said” they replaced the 2 injectors they just replaced..... I find that hard to believe but.... we drove the car home and the light didn’t come on or spit or sputter at this point.
On 7/10/2018 at 2:24 PM, YJSONLY said:
Sooo I stopped by today because I had to get something out of the car. No call just showed up.
Talked to the mechanic myself.... said they have test for leak down test and it all checked out.
Says that it is having a miss but not sending a code for a miss. Only a fuel trim code showing.
Had to dig around. Found that the number 7 plug was gapped/smashed due to carbon build up on top of the cylinder. Said he put new plug in. Ran vehicle and they same code. When pulled new plug was back to close gapping. Said that need top of cylinders needed cleaned of carbon.
Sorry dude but the spark plug gap doesn't get "smashed" from carbon build up. If spark plug gap is truly "smashed" you have a mechanical failure of some sort. I am not buying that explanation.
Like I said I think they screwed up something when installing new injectors. Ie bad seal, o ring or gasket....
So I really drove it myself today vs my wife. And at idle in park the rpm gauge is not consistent. Varies about a solid needle width. This normal?
I would pull the plug on that particular dealer. I think a fresh set of eyes on the problem is warranted at this point. Maybe another Chevy dealer tech has seen this problem before?
And more money out of my pocket to boot tooo. Might come down to that tho. This isn’t a small dealer either.
Sometimes the smaller dealers are way better.
Ha. The other small dealer I took it to. Didn’t even have a tech.... yes a Chevy dealer that had zero techs.
On 7/12/2018 at 10:59 PM, starman8tdc said:
    4.6 hours? WOW! I have never seen any injectors that were not easily accessible. Learn something every day. Any chance you could upload some pics or repair instructions?
    As for the more expensive injectors, I would not go that route - but that's just me. I have had good luck with the cheap injectors on many rigs.
If you haven't done a direct injection repair yet I suggest you watch some videos on it or take a small class. The pressures of the systems are very high, it's important to bleed off the system before you start working on it (pressures can reach 2,000 psi during operation). The high pressure fuel pump is very expensive, so be careful not to damage it when you remove it. And the injectors are high voltage (if I remember correctly) and they are probably a pain to remove because they are in the cylinder and head...I'm trying to imagine how bad it'd be to remove with over 100,000 miles on them. Yikes.
Very few systems use BOTH the direct and port injection together, although that may change with all the carbon issues on the valves, but that is expensive for manufacturers (and they care more about profit than reliability).
Honestly I haven't heard about many problems with the actual systems themselves, more with the carbon buildup on valves than anything else. I used to own a direct injected Lexus...178,000 miles and not one single issue. In fact I've seen cars with 300,000 without issue.
pretty surprised to hear the GM injectors failing at low mileage....even more surprised it's  not covered under warranty. These systems aren't exactly "new" anymore, every car on the road uses them now.
   Good info, thanks for posting.
   From what I have read, the direct injections systems are definitely superior to all the predecessors. I have been working on various cars for decades, but I have not had any issues come up with that particular fuel system.
   I will definitely study the system well before taking one apart.
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
