my 2014 chevy silverado will chirp every time it switches from v4 to v8.  I was reading that there may be a fix for this.  my truck has 40k miles on it and just out of warranty.  Will gm do anything for this since it is happening to thousands of trucks of all different years?
There is a tsb for it so they should. But I also have had the "fix" twice now. The new design doesn't chirp as much but it rattles loudly at idle. The old design you have has two square knobs. My advice would be to bolt it open and be done with it. The new design is not that easy to bolt the flapper open, but you would also be getting a new exhaust so that would be good I guess.
Pretty typical of the Exhaust Adaptive or "flapper valve"  just behind the muffler.
Mine use to chirp also during V4 to V8 and also on warm startups. Thought it was my starter.
Some here have reported GM replacing entire exhaust under warranty.
Option 2 is to clamp the valve open or try to lubricate the heck out of it.
But if i clamp it open i have heard that it can do damage to engine.  Is this a true?
My flapper valve started chirping / squeaking during V4 / V8 transfer at 1500 miles..
Dealership replaced entire exhaust system with new style valve assembly..
Unfortunately, with 40K on truck,, chances are they will not replace,, by give it a try anyway,, nothing to lose...
As others have stated,, either lock it open or just remove..
May be time for exhaust upgrade to better / nice sounding system..
Cheers---K
Just went today to my GMC dealership that sold me my 2015 Sierra last month for this chirping issue. They told me there is a new exhaust system for the 2015’s that will solve this flapper problem. Being under warranty still I will have it replaced within the next few weeks. I also told them there seems to be more vibration in the pedals while in motion than my 2004 model made. They told me the new suspensions are tighter and that there is more vibration felt in the newer models. So it seems newer isn’t always better in all aspects.
Had my 2015 looked at last week for the valve chirp but since I’m 6 months out of the 3/36 bumper to bumper warranty, they wouldn’t replace it no charge. It’s not covered under the 5 year power train warranty. I was quoted $800 for the new exhaust. Figured I’ll clamp it open or put the $800 towards a borla/Corsa exhaust.
Clamp it open and save the cash.
Sounds better clamped open.
A little droning here and there but not real noticeable.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
