2019 Silverado Hitting the lots!!
  • Replies 75
19 minutes ago, TripleBGM said:
I see they have the auto off feature.  I'm really glad I got a 2018 now.
Stop start?  Its defeatable with the switch on the dash.
And a plastic Hood Lever Release? Seriously?
Of course it probably adds up to about .001 MPG more with the reduced weight! LOL
Yes but it must be switched off after every engine start.
I like a lot of the stuff on that truck.  Between the new cool stuff and the 470lbs less weight, it's starting to offset the ugliness.
At least the Auto start/stop is easily disabled.... and not on a damn scroll menu or worse none at all... lol.
Truck payments are like second Mortgages now.
All of us are driving the price up and forcing Manufacturers to cease productions of full size cars! :lol:
If GM wants to outsell Ford, prices need to drop, not increase.
I actually would have thought that Trail Boss would sticker higher than 55k. A current LT Z71 stickers at 50 nowadays, without all the Trail Boss stuff.
They come down. No one's going to be incentivizing the 2019's heavily when they still have a lot full of 2018's to clear out.
I paid less for my 2018 than I did my 2007. Both purchased new, both LT Z71 Crew Cabs.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,364 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
