I’m a very experienced road tripper. It sure is nice being able to just pull into a rest area instead of a fueling event every 200-300 miles. It saves an hour a day at least. Whenever I pulled I had a tank in the bed, mostly tied into the main tank.
  • 1 month later...
The new Sierra trucks are beautiful. I love them.  I am in the market for a new truck and I’m here doing my research.
I am currently driving a ‘15 F150 loaded Lariat with the 3.5 EB.  It’s a company truck as I am typically a GM guy. The truck has been surprisingly great and best of all is the 36 gallon tank since I drive so much.
I was pretty much set on an AT4. So awesome. However, the tank size is a huge disappointment. Perhaps even a deal breaker. I’m sad about it.
The size of the gas tank would not influence my buying choices.
ReallyCat1.jpg.8cecb26b304528d00f4cac7e4d151827.jpg  funny_ghost_face_animated_avatar_100x100_65459_zps6da1501f.gif.8d5c70d6879b89f810db2b3f081bab02.gif
Why not just give the buyer the option ? This is my main gripe. You bring out all this new Towing tech, even go as far as simplifying the window sticker for weights , etc but make the tank even smaller then before.
  • Like 3
Exactly. There should at least be options.
For me its not even completely about towing. I drive 190 miles every single week day for my job. I can’t use a damn Prius to haul things, and a 3/4 ton would be overkill.
I would spend more time standing at a gas pump than I am willing to do.  Even now with the F-150 getting 19mpg with the 36 gal tank I’m fueling up every 4 days or so.
I dont want another Ford :(
So I am enjoying my new AT4 but I have noticed the small tank (extra small with the satisfying roar of the 6.2).  This evening I looked under my truck at the tank and noticed there is about 2 feet of clear space in front of the current tank that could easily be used to hold a larger tank.
Depending on on how bad things are towing our travel trailer this summer  I might have a stainless or aluminum tank fabbed that runs that full length.  I suspect it could fit at least 35 gallon maybe 40 in there.  Unfortunately i suspect the computer will go ape shit crazy when the gallon capacity doesn’t match what it expects.
Given all the space I wonder if we will get a reasonable fuel tank size option when they ship the 60lb lighter carbon bed...
It’s been a while since I posted in this thread and test drive the awesome AT4.
I ended up going back to a Ford with the 36 gallon tank. :(
I still didn’t buy new though, I’m holding out to see if GM pulls their head out.  I will trade this Ford in on an AT4 in a heartbeat if they do. I’m really hoping that the model year 2020 will fix a slew of issues with the new gen trucks.  The tank size being the biggest one for sure. I’m also hoping for tow mirrors and adaptive cruise.... Like Ford has had since 2015.
I was a GM guy for years,  not saying that I would never buy one again but since I began towing a travel trailer I switched to Ford for two reasons: 1) a bigger gas tank, and 2) better choice of axle ratios.  As the gas mileage while towing seems to be about 10 mpg the range was just too short and since I was planning on a trip to Alaska the range would have been way too short.  Then found that the 3.42 axle ratio left me short on power as it resulted in a lot of shifting and high RPM's while towing.  Got to hating the engine revving way up and the shifting between gears.  Am not wanting to get into a Ford vs. Chevy argument but if GM would have had options more conducive  to towing I would probably still be driving a GM.
I don’t disagree on the tank size but on the axle ratio thing I am not convinced. These deep gears on the new 10 speed change the game significantly.
After watching the IKE towing test from TFL where they ran a 9000lbs trailer up the pass at a consistent 60 mph (the speed limit) despite the high elevation and the naturally aspirated nature of the 6.2L. They noted the truck held around 4500 rpm which seems good. Compare that to the poor dodge hemi that was wound tight at 6000 something.
That same test showed the Ecoboost doing a fine job pulling as expected with the turbos giving a massive advantage at elevation. What they didn’t spend enough time on in my opinion was talking about how the trucks handled the trailer from a stability perspective. I am pretty sure I saw some serious sway on the ford in the couple seconds they showed from the chase car. Also not surprising given the heavy squat on the Ford and what that does to unload the front.
With the ford being top of the heap and a game changer for a half ton tow vehicle 3 years ago and now being last in the comparison it seems to me that all these trucks are getting damn good. If you have typical towing needs of less than 10k lbs and tow less than half time it seems like there is hardly any justification for a 3/4 ton anymore.
One more thing... I just crawled under my truck and measured the size of the current tank and the clear space in front of it. The current tank is about 48” long and there are 28” of clear space to the front cross member. With some quick volume calculations it would seem that a 36 gallon tank would fit in there without going any wider or deeper than the current one.
Given that is about what all the rest of these trucks are offering I wouldn’t be surprised to see that option show up in the 2020 trucks. Even if it doesn’t I’m going to TIG up a stainless replacement that is full size for my truck this spring.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 534 Guests (See full list)
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
