1 hour ago, pgamboa said:
Nope. Not yet. Module still with WAMS. No free time :(
Free time? Nope, that’s time you’re essentially paying for! Can’t wait to hear the good news....I mean confirmation that I’ll be spending more money on another upgrade!
Following this as I want to install one in mine but I like the factory look
  • 4 months later...
since I haven't seen a pgamboa video about this subject on YT, I assume it's still a touch further down on the upgrade list..
Yup. WAMS has my cluster and TBCM and CCM. Still trying to get them to communicate.
It seems bizarre to me that GM would make something like this so complicated when an aftermarket box can be added so simply (at the cost of major aesthetic points).
Especially when it seems every vehicle with any of the tow package RPOs appear to have the all the hardware to make it happen.. (save the dash switch).
Yep.  There are 2-3 modules that are specifically for trailer brake.  So those items are omitted...even though some of the dash harnessing is present.
  • 4 months later...
On 2/6/2019 at 7:03 PM, az-4x4 said:
Looks like it can be done now. I'll be trying this out in a month or two.
This is for a replacement, not adding something that wasn't there before.
Not bizarre, it's INTEGRATED whereas the other ones are not.  One gets features not usually available with an aftermarket controller, especially from 2012 on.
I have a question that I can't seem to find the answer to... My RV that I would be towing does NOT have ABS brakes, but the truck would have (most likely, as I am currently without a truck).
The question is... would the integrated TBC have any advantage over say an aftermarket TBC if the truck I purchased did not have it installed from the factory?
Yes, check the owner's manual of the truck you're looking at for specifics.  ITBC controls sway and the brakes on the trailer during sway for example.
Stock controller can't be added later which is lame ...I went with the Redarc controller too, for the remote control ...here's my version
Edited by Pinky Z71
Gents, at the risk of being sounding dense.  I want to confirm that i cannot just purchase and plug in the new dash piece and controller head?  I bought a tekonsha and was wiring it up and took my dash apart and lo and behold theres the harness for it!  The presense of the harness does not prove that im good to go?
Welcome to the site.
No sir, the brake controller is a factory option, and is set up in the ECU, BCM, and so on, it can not be added after the fact.
    • In the 6.6 gas thread, I added information in my fluid change thread about these gauges and temperatures. With very limited data, it so far looks like ~30 degrees difference between front and rear.
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
