2014 GMC Sierra 1500 SLT. When air conditioner is on, I am getting warm air out the drivers side vents. Passenger side vents blowing cold air just fine. Have the problem in both manual a/c mode and in auto mode. Just started yesterday. Any suggestions? Tried a search on here but only found this issue on prior 2014 trucks. Any help would be appreciated. Thanks.
A day later it started working again correctly on it's own. Not sure what it did to correct itself. Will report back if it does it again.
  • 10 months later...
On 9/5/2018 at 6:56 AM, silveradosid said:
left side temp sendor or blender door stuck disconnect the battery for 5 minutes and see if it resets
Well it's happened again! Doing it for 3 days now. Going to try to disconnect the battery for 5 minutes and see if it fixes it. Will let you know if it worked.
Disconnecting battery for 5 minutes worked. For now. Will see how long it lasts.
Is this still holding up for you? I have a 2019 Silverado that I bought 4 days ago and I just now realized that my driver side is stuck on cold. This isn’t a terrible thing because I’m in Florida and it is still a million degrees outside, but since the truck has less than 40 miles on it, I’m kind of pissed haha. I’m going to disconnect the battery when I get home and see if that works. I’m at work now and it’s sitting in the parking lot, so, maybe after sitting for a few hours, it will reset on it’s own too. We shall see...
No, it's not holding up. I have to keep resetting it about every second or third time I drive the truck.  Yesterday it was blowing warm air out all the ducts with AC set on 60 degrees! Once again I had to pull the negative cable off to reset the system. Normally it just does it on the drivers side. I am sick and tired of pulling the negative cable off. I am thinking of contacting GMC to see if they will help me out in the repair of this. It just turned 50,000 miles and this shouldn't be happening already. It's a good thing your under warranty. Let me know how you come out or if you have to take it in, what they say. From what I have read many have this issue going on.
That sucks. I’m going to try the battery reset and if that doesn’t work, I’m definitely taking it in. I will post my results here. Thanks for your update.
Yeah, post your outcome. Thanks!
So, call it bad luck, but my actuator was bad. Straight from the factory haha. The mechanic said “one in a million” haha. Anyways, that part isn’t readily available, so, they had to order it from Detroit. Had it in a couple of days and installed it in a couple of hours. Good to go now.
One in a million maybe on a new truck but get a few years on it and look out. 1 in thousands. Weak point on these trucks. For what they cost, cheap parts are being used in building them.
  • 11 months later...
I thought my 2014 Silverado A/C was bad. I just realized that my passenger side vents are blowing cold when my drivers side vents are blowing warm. I guess it's  been this way all summer because everyone riding in the passenger seat has complained of being cold while I've been hot so I  thought they were crazy.  I've added freon and taken freon out and nothing helped. I don't know about the battery reset because I put a new one on about two weeks ago. I am going to disconnect it and pull the fuses to see if that helps.
Mine started doing the exact same thing, driver side warm, I can "fix it" by turning the temp control to full warm and back to cold.  2014 SLT, looks like another actuator problem.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
