Threw this in today.
  • Like 4
8 hours ago, BlackLS said:
Looks great.
Did you need to run spacers to clear the calipers? How far do the tires stick out past the fenders?
Thanks!  No spacers needed, I got the updated re-worked wheel that fits on the 2019 with no issues.  Here is a side shot.
  • Thanks 1
Reworked? I heard alot of rims are going in for some kind of repair of fix. Is this what you are talking about?
Sent from my SM-G965U using Tapatalk
Yes, all the manufactures have to go back and re-machine the wheels so they will fit.  Fuel has updated almost of their wheels now, so any of them will fit.  But if/when you order you need to make sure to clarify they are for the 2019 model, especially if you order online, as they may send you an old model that’s been sitting on the shelf and not redone.
Thanks I tried to order a set last Wednesday and they said stock was sent back. To be worked on. So that makes sense.
And sharp truck
14 hours ago, NKHex19 said:
Sick! How is the fit when the seat is down? Also did you install it yourself?
Simple install.  Sub is just a stock JL wedge box, plenty of room. Amp was straight forward, especially when using a LLJ Customs adapter harness in to the Bose system.
23 hours ago, NKHex19 said:
I ordered the lettering from BD Trims. In fact it will be delivered today. I have a white RST and went with the domed glossy black lettering. If I get them installed today I will be sure to post a picture. The posts I’ve seen with them installed look great.
Well?
Until my cheap ass gets a phone with cordless charging I re-routed the USB cable from inside the center console to where the phone sits.  I know it could just plug into the dash USB but my wife uses that one.  The cable tucks into the console or pulls out as needed...
No more cable in the way of my seatbelt or the cupholders now!
Edited by Limelight
was this easy to do or do you have to pull the entire console out to get wire underneath?
Nope super easy.  Pop the drivers side of the console out a bit by where the seatbelt release is, open the console lid and release the 2 clips next to the latch holes and pull it up a it.  Feed the cable and done.
Takes 5 minutes.  If you want to know how to release the center console clips go to the website for the Autostop Eliminator.  They have instructions for where the console clips are, but you won't need to take it all the way out.
Removed the decal from my tonneau cover and I found some LED's that fit the spot perfectly.  These are submersible and only 1/4" high.  10 of them for 12 bucks on Amazon and they arrived in 12 hours!
Edited by Limelight
  • Like 3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
