How have you guys been swapping the blinkers? I am having hell and really don’t want to disassemble the grill.
It's not located where you think it is. There's a knob without a pigtail attached. That's the actual bulb socket. It's a little higher up. Look at the light from the front to approximate where the bulb is, and locate the knob on the back in that general area. There's some sort of electrical wizardry going on there.
You got balls to try that with zero experience. [emoji106][emoji106][emoji122][emoji122]
Sent from my Pixel 3 using Tapatalk
My options were:
1) Take it to a shop and pay a lot of money, or
2) Try doing it myself and save a bunch of money.
If option #2 failed there was always option #1 as a fallback plan. I can afford option #1, but wanted to save as much money as possible.
5 hours ago, ice_nyne said:
Swapped out the halogen turn signals and reverse bulbs for LED.
Wish all work was that easy!
This has to be like thing 1 for every Silverado owner!!!  Glad to see it.  Wish GM would just do it for us.
Edited by fsuboy75
Replaced the TB decals with all black ones.
Replaced the chrome/red Z71 badges with black/red ones.
Installed 1.5" leveling spacers.
Cut out muffler and flapper valve and installed Flowmaster FlowFX muffler.
  • Like 3
Where did the all black TrailBoss decal come from? I removed mine all together, but that might make me put it back!
Probably ebay
It’s either that or tinting the front windows to match the others as mod 1.
But yeah, ridiculous that GM isn’t consistent with its LED lighting.
I left my truck sit in garage all weekend and today because we got another 5 inches yesterday and after spending an hour cleaning it on Friday night. It was gonna stay clean.  Drove wife’s Acadia to work. That thing is a lot easier to clean than my “tank”. Can’t believe how much bigger these trucks are compared to her Acadia.
LOL, i just swapped a 2500 for another 1500 and it feels like a honda civic.....amazing how small my new elevation feels
That’s too funny. Ya this T1 standard box is a h@ll of a lot bigger than my K2 short box. And twice as big as my wife’s Acadia. I can clean and dry that in about a half an hour in a heated bay. My truck takes about an hour and ten minutes.
Edited by TNTSilverado
I just did the same to my exhaust. I'm loving the flowmaster fx muffler. How are you liking it?
I love it so far. Just gotta get rid of the leak and all will be good. Just bought a flux welder at harbor freight and gonna teach myself. Hold my beer....watch this!
Edited by SHKBAKE
Added words
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
