2 hours ago, Jake rome said:
3.5 rough country lift and some new XD wheels...... just picked up the wheels and tires yesterday, not sure if I love them or not....
Looks beautiful !!   Not overly done...Any specs on the tire & wheel size, offset, ...thank you.  Again very well done ?
20" x 9 wheels +18 offset 295 60 20 tires. I love the set up I kinda just wish the lip was a little bigger but then I would have had them sticking out much more then they are now. I also think I might have liked a smaller tire as far as height. These are a little over 32". But all in all I really like the set up and it drives amazing!
On 11/13/2019 at 7:37 PM, STX30MAC said:
2019 SLT X31 6.2L
8k miles
6in Bds on stock 20s with 35x12.50 Nitto RGs
Just picked mine up last week.  Looking at doing same thing.  Any rubbing, cutting or bending with those 35s on stock wheels?  Thanks.
On 8/27/2019 at 7:06 PM, STX30MAC said:
My New ride.  2019 Sierra SLT- X31-6.2L with 6in BDS on 35x12.50 Nitto Ridge Graps
Looks great.  Any issues with 35s on stock wheels.
Justeegs, did you paint the green logos and recovery hooks? Or are they wrapped?
3 hours ago, Jsteegs said:
Kawasaki used to paint their motorcycles that color of green and I believe Arcric Cat had a variation too.
Here my 2019 Sierra SLT X31 with the 6.2. Had the dealer install the factory 2" AT4 lift kit on it, as well as the Rough Country levelling kit for the AT4 suspension. Decided on the 275/65/20 BFG K02.
  • Like 3
So your saying you have a 2" suspension lift and a leveling kit installed on top of that? Man I would love to see those CV Shaft and ball joint angles. Iam surprised the dealer would even do that.
I am pretty sure he said he had the factory 2” lift ( which you can purchase) then had a leveling kit installed.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
