On 11/22/2019 at 7:35 PM, Parb said:
Just picked mine up last week.  Looking at doing same thing.  Any rubbing, cutting or bending with those 35s on stock wheels?  Thanks.
Took the lower valence off then trimmed the corners off the large valence. Had to trim the mud guard behind front tires pretty good.  Still rubs the front wheel well front liner at full lock in reverse.  Turning quarter turn into a steep drive way and they will hit the back wheel liner pretty hard. but its just for 1/2 a second.  Still want to get some 20x9 +0 black machined wheels.  should push wheels/tires out 2 inches from where they are at now. then I will have to trim some in the front wheel well back.
On 11/4/2019 at 2:14 PM, Elevation 2019 said:
After 4 years of no truck picked up a 2019 Elevation.Traded the ATS in
Wow, that color with the black looks so good!  Haven't seen that combo before. Congrats
11 hours ago, Comscan said:
Awesome colour.
Thanks, I wasn't sure about the color at first but no regrets.
When you get the perfect parking spot at the hotel to keep an eye on your baby from the porch...?
  • Like 4
Nice! Been there done that lol... glad I’m not the only one. Nice truck by the way...
Lol- now I don’t feel to guilty for sitting on my front porch every night with a coffee looking at mine. We are pathetic!  I love it.
I’d be doing the same thing. I’ve had mine for three weeks and every night I look out my bedroom window at it before going to bed lol
10 hours ago, jimmyboy8301 said:
7bd6109d4fa305cc48a6031741452946.plist
You need to change your signature amigo....
Why does he need to do that?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
