Just got Fuel Throttles 20x9 with Nitto Ridge Grapplers 285x60x20 put on this morning. (Wheels fit without spacers FYI) 1” lift in the front, windows are tinted and I have a Pace Edwards full metal jack rabbit cover.
  • Like 6
1 hour ago, RyanbabZ71 said:
Ryan B.
Thats is awesome to get the inside info and pics on your truck!
Edited by smrr1
[emoji6]
Sent from my iPad using Tapatalk Pro
35 minutes ago, VanOtter said:
Picked up my AT4 last week... 1st mod will be a tonneau cover
That thing looks great! The AT4 is a heckuva looker!
What cover are putting on it?
Get rid of that ugly antenna while you’re at it... ??
Get rid of that ugly antenna while you’re at it... [emoji85][emoji16]
Can't lose the antenna. That's how you know if you'll fit. I don't fit in any parking garages in Orlando
Sent from my SM-G975U1 using Tapatalk
The ugly antenna GM puts on these trucks is a good foot higher than the truck.
Take it off, leave it in the cab, then hold it out the window as you approach the garage... ?
Considering the Hard Rolling Cover by Rev or the Retraxone MX Polycarbonate cover. Still haven’t decided...
Nice advice — it reminds me every time I pull in/out of my garage [emoji15]
My wife was at the dealer today for a new windshield for her 10 day old 19 Denali XL. The sneaky bastards sent her home with this as a loaner. I think we’re keeping it [emoji1750]‍[emoji3603]a93588dcc26b2a49bb9e811659f42ee0.jpg90a101373cd71835376d2c1cf82b3ae9.jpg
  • Like 6
  • Haha 1
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
