59 minutes ago, AMPRG said:
One generation is missing between the first one and second one from left. My 2005 was different.
Yes the gmt 800's from 03-06.5, also technically the 14-15 silverado is missing as well but still cool to see the progression next to each other.
Man is the gmt 900 such and ugly duckling, worst gm fullsize ever made imo inside and out.
Edited by BIGDOGx
Yep, the "cat eye" model. I had an '03.
Is that the Havana brown?
Yes sir, it is
Sent from my SM-G965U using Tapatalk
Just got Fuel Throttles 20x9 with Nitto Ridge Grapplers 285x60x20 put on this morning. (Wheels fit without spacers FYI) 1” lift in the front, windows are tinted and I have a Pace Edwards full metal jack rabbit cover.
Do the tires rub at all and what is your offset on your rims please. Thanks for posting
New to this forum. Not new to Chevrolet. Just purchased my new 2019 Silverado LT Trail Boss in Northsky Blue. Only extras are tonneau cover and window tint. Love the truck so far.
  • Like 11
2 hours ago, RyanbabZ71 said:
Ryan B.
Damn I love the way the standard bed looks
I’m not sure of the offset.
I had to cut a little bit of the mud flap, just a little overlap of the mud flap and the wheel well. It’s nothing you can see from the exterior.
On ‎2019‎-‎05‎-‎02 at 5:15 PM, RyanbabZ71 said:
Ryan B.
What's up Ryan?????
On 4/24/2019 at 8:44 PM, KozzyJr said:
Is that a doodle? We have one also. If you don’t mind me asking, how much for the entire truck to get PPF?
Haha yes it is and I’m a PPF tech. So you know ?
  • Haha 1
the GMT 800 was 99-07 (classic) whether it was a 99-02 or 03-07 it's still the same generation. same goes with 14-19 (classic), even though the 14-15 were different they're still K2's.
Great looking rig, especially in person.  The Chevy can be polarizing in pictures but having seen a bunch now I have really grown to love it.  In my opinion, the best looking new pick up out there.
  • Like 3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
