18 minutes ago, pappavol said:
Looks great! What size RGs? Any level to clear?
They are 295/70/18 1” motofab, no rubbing at all. I did see a little drop in MPG but the tire is 10#s heavier than the stock duratrac.
The lift was a very easy install with a few leveling jacks and basic tools. Took it back to GMC for alignment check. They covered it under warranty, they didn’t say anything about lift and tires and neither did I. LOL
  • Like 3
  • Haha 1
1 hour ago, pappavol said:
Similar but I wouldn’t say they look the same at all,
Nobody else has said that either.
Soooooooo I rocked the stock height with 35s but then I hated that everyone else with 35s was taller than me. So here she is with 4"lift and 37s35bb1cd9398b8502e2c9eb57a6de0808.jpg672473f7a89ab023fe2b0401b9fbb258.jpg
Sent from my SM-G975U1 using Tapatalk
  • Like 6
Where’d you get the lift at?
Also. Is this only a 4 inch lift. Looks freaking sweet!!!
Readylift SST?
Thanks. Yes it's a rough country 4" added to the stock 2" taller at4 struts. The 37x13.50s did require me to trim a little but I love the new look827f7e24fbbc8ae5094b7d666585b8c2.jpg
Like that lower bumper. Who makes that?
Moved from 2014 Z71 LTZ to 2019 RST 4x4 and could not be happier! I think Chevy knocked it out of the park with the redesign.
Shes a a month old now and 2300 miles already.
6” BDS lift dealer installed
20x9 1 offset Fuel Schism wheels
325/60/20 Fuel Gripper A/T ( A. Didn’t know Fuel made tires. B. Was really hesitant about these since they threw them on in the package. Tried to talk the dealer into throwing KO2s on there since I’ve rolled BFG for the last 20 years, but they actually ride really well)
  • Like 7
6.2, Performance Pack, Color Matched wheel arches, Tint, Tonneau, Black Badges, Ceramic Coated, K02s on Gloss Back GM Wheels...waiting on readylift kit for AT4
Readylift BMC
· a month ago
No sir, we do not recommend stacking an aftermarket leveling kit with the factory Trail Boss/AT4 2" leveling/lift kit as you will eventually experience ball joint issues. We will have a AT4/TB version kit with new control arms with proper cup and pivot angles available shortly.
IMG_0478.thumb.jpg.bf2db95c21846e90bc06eab8122fbee7.jpgIMG_0479.thumb.jpg.e6d37abea7d74cb4618a73687c71fe85.jpgIMG_0476.thumb.jpg.7fa6ef0c8094a230cc144f7a6b973b52.jpgIMG_0480.thumb.jpg.e53768fd66d54dec6a17312cc2d8ae8a.jpg
  • Like 3
I went from a 2007 to a 2019. Huge difference, happy so far.
Swapped the Good Years for Cooper discoveries 295/70R18. No rubbing, drives good.
Bunch of nice trucks on here :thumbs:20190511_101611.thumb.jpg.4d912f1592f183028f35c91ba6509e48.jpg20190511_101916.thumb.jpg.ddb460840295a0e9ec30590852b1ca58.jpg20190511_110217.thumb.jpg.4bf179f8a3046b16f936338d4f15553c.jpg
  • Like 5
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
