Finished everything up. Had to make my appointment for the alignment next Friday due to shipment delays. 1.5 motofab & 35 12.50 18 Ridge Grapplers with 2" Bora spacers.
Any rubbing with this setup? I want something similar when the time comes. So over factory trucks you have the 2" TB lift and then the 1.5" moto for a total of 3.5", how are your cv angles? Any close up pics of suspension parts would be appreciated. Truck look great btw
Sent from my ONEPLUS A6013 using Tapatalk
Thanks definitely loving this setup a lot! So, in front of the front wheels, nothing at all as far as rubbing goes. In the rear of the front wheels, I had some and I found the best way to eliminate it was to remove the bracket behind the fender liner and trim the mudflaps. As soon as I did that, full turn forward/reverse over curbs, etc and I've got plenty of room with no rub whatsoever. I'm doing some finishing sanding on the flaps to make them look factory. No crazy angles but next weekend after my alignment, I'll be checking all my torque values once more and I'll snap some pictures.
Edited by ETMC
Misspelling
Awesome. Thats not bad at all if all you had to do was remove the bracket and trim the flaps.
Zone has a 1.75" leveling kit. has anyone bought this kit? I'm thinking this is the lift i will go with.
http://zoneoffroad.com/1.75-Leveling-Kit-2019-Chevy-TrailBoss_and_Sierra-AT4/c1171
1.75" Leveling Kit
Here's some of the information.
  • 3-piece design with top mount spacer and 2 preload spacers to raise ride height without over-extending suspension during droop travel
  • Maintains ride quality and handling characteristics
  • Allows clearance for 33-34" tires
  • Includes Factory Protection Plus
Zone Offroad is now offering leveling kits specially designed for the 2019 Chevy Trail Boss and GMC AT4 trucks. Engineered to be more than just a "budget boost", these kits are designed to a higher standard to work within the parameters of the factory suspension and steering geometry to maximize its potential while allowing clearance for larger tires. As with all Zone Offroad lift kits, these new kits are backed by Factory Protection Plus for piece of mind wherever your adventures may take you. Factory Protection Plus includes Zone Offroad's Limited Lifetime Warranty, ESC system compliance and a 5-year 100,000-mile drivetrain warranty.
Important Notes!
  • 1. Strut compressor required for installation.
  • 2. Will not fit Adaptive Ride Control (ARC) equipped models.
  • 3. Tires wider than 295/ cannot be installed on factory wheels due to clearance issues to the steering knuckles.
  • 4. Welding required to install optional LCA steering stops.
  • 5. Complete 1.75" leveling recommended for AT4, Trail Boss suspension not as raked for the factory so installing without thin preload spacer will net 1-3/8" lift for a level stance.
Hope this information helps.
On 7/14/2019 at 5:58 PM, Sin City Trail Boss said:
If I remove the rear block on my TB, what do I replace it with to level it with the front?
Smaller block and U Bolts. A show here in town just told me they had another Trail boss do that and it leveled the truck. You'll need smaller U bolts
When you have time, could you please take a couple pics from straight-on front and back? I'd like to see how far the tires stick out from the fenders. Also, in your estimation, do you think you could get by on 1" spacers?
^^I hope your going to put flares on that truck, otherwise kiss your paint good-bye. GM's post-2010 paint is not up to the task of beings pelted with rocks and sandblasted daily.
Here’s my alignment sheet from this morning. Hope it helps.
Please tell me what I'm looking at. This good or bad? I see green..
Sent from my Pixel 3 XL using Tapatalk
On 6/10/2019 at 8:10 PM, jtl1985 said:
so what does everyone run for tires with the leveling kit on a trail boss lt? I ordered the understrut kit and prefer to have a little bigger tire. keeping the 18's but do I go 33" or bigger without rubbing issues? I've always had to trim and I really don't want to this time, maybe just he mud flap if I have to.
i run a 33x12.5 on 20s with my trailboss
  • 5 weeks later...
1.75" Leveling Kit
Important Notes!
I am having this kit installed tomorrow with TOYO MT 295/70R18’s on factory wheels.
Before installation
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
