49 minutes ago, GT87 said:
Does Borla not make an ATAK catback for the 5.3? Everything I see is for the 6.2 only.
There is no atak for the 5.3. I was concerned but I ordered the s type anyway for my 5.3. Sounds perfect and I wouldn’t want it any louder
I wonder if there's an ATAK in the works? My concern would be the s type is not loud enough for my taste. Do you have a sound clip of yours?
They told me that they will not be coming out with an ATAK VERSION for the 5.3. The only video I have right now is a warm idle. It’s plenty loud. If you want some videos message me and I can send them
1 hour ago, KozzyJr said:
Anyone jump on the touring yet?
I was interested in the Touring but Borla doesn't have any sound clips for it. I emailed them and they said they don't currently have sound clips of the Touring. I'm very hesitant on dropping $1200 on something without at least hearing it first. Currently leaning towards the Gibson cat back. It's less than $600. More willing to take a chance on that since it's half the price. I prefer tamer exhausts. The consensus i'm getting so far seem to indicate the Type-S will be too loud for me.
I had the s type before on my 2014 6.2. Way to loud, and the drone at 2000 rpm was rediculas. my kids always had head aches after a road trip to camp.
Edited by KozzyJr
The new Type-S and Touring are reported to have no drone. I think i might go with the Gibson. We shall see.
The Touring is very close to the GM/Borla system. Mild sound.
Do any of you guys have the single exit exhaust? I have the 2019 sierra SLE with the single passenger side exhaust. Does gibson make an exhaust that would work with the single exit side?
You tube my friend. Pretty much every exhaust company has a single side exhaust. Longer the muffler the quieter it get. If you want a mild setup look up magnaflow in a 18-21 inch.
I know I can go for a muffler route but I didnt know if anyone saw any good cat back exhaust options. Ill keep researching.
Edited by jordanl010
On 3/13/2019 at 6:45 PM, ARTLFT said:
I just bought a 2019 trail boss and added a Borla XS muffler. These are some videos of what it sounds like. Excellent growl when you put your foot on the pedal and complete quiet when cruising. Neighbor and baby friendly!
FA8ACC28-3F7E-4D99-B627-8D875347924C.MOV
I couldn’t get the links to work either. Do you have the sound clips on YouTube? I was thinking about doing a straight muffler swap too. I’m just looking for sound but don’t want the drone. My 2017 Silverado has a terrible drone with a Gibson exhaust.
Make sure you keep your flappers just in-case there is drone. I went with the Magnaflow muffler. You can can read about it here.
Thanks! My local shop recommended the Magnaflow. I’m wondering if I go with a Flowmaster and keep the flappers, if that would sound more closely to the GM performance exhaust...
The Flowmaster is definitely much louder than the Magnaflow. Even without the flappers, the Magnaflow sound was pretty tame. I think the Flowmaster with flappers will still be a bit louder than the GM performance exhaust. The GM performance exhaust is really tame.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
