Well at 52k miles my 2015 Sierra 6.2 8sp has started to shudder again. Aleady had the torque converter replaced twice first at 16k and than at 34k, a yearly occurrence it seems. Its pretty obvious why gm dropped the 100k mile warranty. Whats the chance gm will actually come up with a fix for these transmissions or will they just abandon us that own them and hope we are dumb enough to trade into a new gm truck?
Edited by hotrdlx
If it is the torque converter then what if you buy a performance aftermarket one?
I thought there was a fix for these now from what I read. YES or NO?
Yes my wifes 16 6.2 8spd we went straight to a yank 3000-3200. No more issues
Since it is still under powertrain warranty i dont want to modify it with a tune and aftermarket tc as im afraid of having an issue and my warranty being denied.
As far as a fix goes gn flushes the trash out of your transmission (how much damage has been done or is being done by this) than if that does t fix it they put in a new torque converter. Each one ive had has been a different part number so apparently the updates have not resolved the issue. I believe the real issue is in the transmission tuning and trying to get mpg by sacrificing reliability.
Have a read:  https://www.gm-trucks.com/forums/topic/216529-16-na-175-8-speed-shudder-update/?tab=comments#comment-2170837
I just got my 2016 Sierra 6.2/A8 back from having the flush done. GM is no longer replacing any torque converters until after the beginning of the year when the new fix comes out 2019 Q1.
On 11/10/2018 at 8:14 AM, Roscopcoletrain said:
there is a fix coming in the new year according to the latest tsb posted in here
I had mine replaced last year at about 110k miles (2015 Silverado LT) and it just started shuddering again today (125k miles). Wondering if last years repair is still under warranty...
at 110k miles I assume this was out of pocket expense and not under warranty?  If so, curious what you paid for the replacement?
can also try the OEM converter from the ZL1 SS Camaro, it's about $350
if it shudders stop driving 'cause you can damage the pump, and send metal debris through out the system
Edited by flyingfool
Better design?
idk... can lurk around the camaro forums and ask what they think..your the guinne pig
if this will be your 3rd time, that can fall under the lemon law (same problem 3 times) so look into that. You may be able to get GM to buy that truck back.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 480 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
