Would the 2” motofab level clear the tire from  the control arm that he was hitting?
Can’t tell if you’re saying you have the 2” level in the front along with the 2” factory lift or not
Edited by BPVTB
14 hours ago, TrailDemon said:
Full photo of the truck with 325/65/18 on OEM rim, 1/4 spacers & 2” factory lift
You were able to fit them without any rubbing or trimming after the 1/4” spacers were on? After installing them, do you think a less knobby sidewall tire could fit without wheel spacers on the factory rim? And also, are the tires flush with the fenders or do they poke out a little? Pic?
On 5/10/2019 at 7:27 AM, Trailboss91 said:
Curious what did this do to your MPGS when you put them on?
If I'm cruising at 60mph DIC says 19mpg, 17mpg average city/highway after a couple weeks of driving. I've never calculated it. I'm happy with the mileage.
Truck came with 2” lift from factory. I didn’t modified suspension at all.
Yes, I was able to fit them after installing the spacers. If the  sidewalls weren’t knobby I could get away without wheel spacers and they tires are flush.
Old tires were donuts for sure lol
  • Haha 1
nice
Well that definitely puts it in perspective ?
Looks great I’m might try same size only with BFGoodrich ko2
I was thinking the same thing...you first :D
On 5/7/2019 at 9:03 AM, asalinasz39 said:
Your setup is perfect brother. Compliments to the stance and those running boards as well!
Edited by rikhek
On 6/7/2019 at 10:59 AM, TrailDemon said:
I’m liking those running boards.
Interesting.  I'm not sure why someone would spend the coin to install taller tires for improved ground clearance on your 4 wheel drive only to then lose all you've gained and then some by installing handicapped steps that hang 8" below the rockers!?!?!?  Seems like an exercise in futility???
Calm down boss, 90% of the people on here are installing bigger tires for aesthetic purposes, not off-roading. They fill out the wheel wells better. Didn't realize we were upsetting a consummate professional off roader. Guess its a good thing its not your truck.
  • Haha 2
I don’t understand why steps hang down so low either. I don’t offroad near as much as I used to any more but clearance beneath the steps concerns me. However I also fail to see the point in that comment.
It’s someone else’s vehicle. Let them do with it what they wish.
  • Haha 1
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 868 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
