1 hour ago, hiranger said:
I had purchased mine in March and only been driving to work (4.5 miles each way) so I didn't ever see, November 11th we went to the In-laws and it was raining, My 10 year old says I'm getting wet, It was scheduled for its first oil change on the 26th, said they would need to keep it for about a week, I told them I would need a loaner can't be without wheels for a week, so I had to wait almost 1 month, they call, I drop mine off and pick up a 2019 Z71, last night we are coming back again from my in-laws, we stop to get gas and my 4 year old daughter Mon! this truck leaks in the same place as daddy's truck!
My Silverado
Their Loaner Z71
Lol, wow. This is really going to turn into a huge issue for GM.
Got mine in March 2019, too. It was a Feb 2019 build. Started leaking after 8 months, 7000 miles... which seems like a lot of people’s stories right now. With winter and spring upon us, the dealerships are going to start seeing a LOT more of these.
With as big as this thread is, are there any trucks out there with significant time and mileage that do NOT leak? If so, I wonder what the difference could be between those that leak and those that don’t.
I used to think this was an issue isolated to specific build dates. But in the past few weeks a lot of us 2019 builds and even some 2020 builds are saying they are leaking. So methinks this issue is much worse than people think.
I will safely speculate to say that nearly every T1 will have a leak at some point.
2 hours ago, SamDSJR said:
So we got our first rain since my "fix" and sure enough she's leaking. In for the second repair she shall go tomorrow.
This is crazy, because lastnight it wasn't even raining hard when my daughter noticed the loaner was leaking too. Monday I'm calling Chevrolet and asking them to replace the rear window, I was reading that's the only real fix.
1 hour ago, ryan030389 said:
This thread has me nervous. February 2019 build. I purchased it new in September. No leaks so far. 4400 miles now
Mine was a Feb 2019 build and it started leaking around 7000 miles.
Good luck. It’s not really the only real fix, as there can still be some seals on the spoiler that leak. But it’s the next step if they already resealed your window.
Been raining the last two days on and off and no re-leaks yet. But man, I'm checking almost every day. This isn't mentally healthy. Didn't start leaking until 12k miles. Nov '18 build, bought in March '19. No leaks until December '19. I would bet and agree with @econometrics that this issue affects all Silverados. There are only two types of Silverados, ones that have leaked and ones that will.
  • Sad 1
I probably had less then a 1000 miles on my 2019 when I first smelled a bad odor. I thought for sure the carpet had gotten wet but I could find no evidence. This happened several times over the next couple of months until I finally discovered wet carpet just inside the drivers side passenger door. I started researching and found this forum and that;s when I realized it was coming from the rear window. My window is leaking on left and right side. There was water in the sliding window track and the plastic trim around the window is cracked. Going to the dealership a week from Tuesday. i wanted to get the holidays behind us so maybe the technicians will have a little focus. I'm going to stress a new window be installed because of the large crack in the plastic trim around the sliding glass. No amount of new sealant is going to fix that issue. So we shall see what happens.
I don't think the solid rear window is included in the leaking.  I posted in another forum. It seems like it's not IF it's going to leak but, WHEN.
I was dreading it before but now I’m really worried about it because I just had my interior redone with katzkins leather the last thing I was is some greasy tech getting hand prints all over the inside of my truck. Not to mention the horrible sealant and scratch job that comes along with the exterior part of the repair
Right, I think the solid rear windows are fairing better. I guess I haven’t heard if anyone here with a leak has the solid window? I assume we all have the sliding rear.
But, seeing how the spoiler is attached to the cab, and the poor engineering for water flow there, I could see how the solid rear windows could leak at some point, too.
Main issue here seems to be that the sealant doesn’t keep the seal after some time goes by with the truck flexing and freezing / cooling, etc. Both sealant on the sliding window frame, but also around the spoiler bolt locations.
I think part of the issue is the slider window has a piece of plastic for the window slider in-between the glass and gasket. The solid window is just glass and gasket but I would have to double check on my loaner. It's just a bad design all around. All to add a stupid spoiler that doesn't even look that good.
Sent from my Pixel 4 using Tapatalk
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
