33 minutes ago, TenshiWingusu said:
I hear ya. I would check the resistance on the new switch in both positions, you can force the latch closed with a screwdriver then pop it with the interior hood release. If the switch is in the spec mentioned above it's either bad wires somewhere or the control module has issues.
Yeah hey. I wonder if the dealership can silence the alarm that would be perfect as long as theres no ringing id be happy lol
Do you think if I unplugged that sensor and got a aftermarket remote start would it work? Or would the aftermarket remote start still need to know that the hood is closed so would have to stay plugged in
Can someone please show me a wiring diagram and pins on bcm. This truck got in a wreck and has a different wiring harness, but came stock with a hood switch with no pigtail
  • 5 months later...
What model year truck do you have?
I have a 2008 Chevy equinox that the factory remote start stopped working on. No service engine lights. No indication that a door or hood is open. I’ve changed the gas cap and even checked the tire pressure even though no lights indicated such problem. However I’m still having the same issue. The remote start won’t start the vehicle. The key fob locks/ unlocks the vehicle any and every time a button is pushed. Even illuminates the light when attempting to remote start but it’s like the process just stops. I’m lost definitely could use some ideas and can’t afford a garage to fix it.
One evening my 2018 stock alarm went off...I thought I must have hit the panick button on my remote...
The next morning I could not remote start the truck...
I get in, start it, and my hood open message was on with my check engine light...I checked the hood several times and it was opening and closing as it should...
Searched and found this post, measured the resistance between the black and red wire on the hood sensor connector and it read 529 ohms ope or closed.
Replaced the hood sensor and it fixed the open hood message and then I had to clear the code...
Tempatures were in the 20's to 30's and I had 51,000 miles...Makes no sense.
Hey Everyone, just had this problem on my 2018 Silverado LT. I think i found the issue. If you go to the hood with it closed and push down lightly on the hood even with your finger it will have some play. Open the hood, there are 4 rubber "standoffs" i'll call them. They keep the hood a certain distance from the plastic cover on the inside. turn them to the right they go down, turn left they stick out further. I just loosened mine so the hood would stand off the truck a bit further this makes the hood engage the latch more to hold it down. I think that movement of the hood was making the sensor think the hood was open because there was no pressure against the latch from the hood.
On 2/17/2019 at 1:57 PM, Linden16 said:
Yeah its the whole late assembly correct. So i installed that and still have the same problem yup.. not sure what else could be causing it. And like i said it only rings when the trucks cold. After a few minutes of driving it stops
Hey y’all just wanted to post that I tried the resistor and it worked!  I bought 2.2k ohm resistors off Amazon and soldered it in.  I was getting +\- 520 ohms with the hood open or closed so I knew it was the sensor.  Thanks for posting!
Edited by Jason56
Can you post a link to the resister?
Thanks
Jim
The resistance values (ohm's) stated earlier in the thread are correct, ~740 and ~2.2k ohms for opened and closed respectively. The linked 2.2k ohm resistors should work fine bypassing the switch.
For anyone having the issue, GM has a TSB out for this specific issue as well, regarding loose/bad grounds. If the resistance values of your hood switch are within spec. You may have a bad ground.
In my case it turned out to be caused by the ground braid (labled 3). Under the hood on the drivers side firewall. It is a thick braided flat steel cable bolted to the body cowl, bolt was lose an jiggled around. Throwing hood sensor codes (short to battery & open circuit). You may need to check the opposite end of the ground braid as well on the left rear cylinder head.
https://imgur.com/a/kddguGK
I have a 2014 Sierra Denali 1500. The hood open alarm comes on when I have to much going on inside the truck, for instance if I have my AC full blast and AC seats (passenger/driver) going all at the same time the alarm will start to chime. I unplugged it before and it stopped. I was able to continue as normal. I am not to sure if it’s just the hood sensor or if the problem may go deeper, like to the BCM. Can anyone let me know if changing the sensor out would be the fix?
Thanks
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
