Has anyone reset their TPMS system? I have another set of take off wheels on the way for winter tires and would like to know which reset tool to purchase. Will the tools that work on the previous model GM systems work on our 2019 trucks?
Thanks.
Thanks.
I had Discount Tire attempt to do mine since I have aftermarket wheels and different OEM TPMS sensors but they were unable to since there tool did not include the 2019 Silverado and didn't work when set to 17 or 18 model year either.  I figured I'd wait a few months and try again.  Yo be honest, after a few days, I barely even notice the TPMS light now other than the pop up message that comes up when you start the car
Winter tires arrived (Michelin Ice-X) mounted them on a set of Chevy 2019 Silverado 18 inch wheels with oem TPMS sensors...after about 5 miles, TPMS  warning came up on dash in tach.
 I will order one of these and report back.
Bob V
22 hours ago, z1boss said:
Here is the same one on Amazon.  Just ordered it today.  Will let you know if it works.
https://www.amazon.com/VXDAS-EL-50448-Pressure-Monitor-Activation/dp/B072BK693N/ref=sr_1_3?ie=UTF8&qid=1545143523&sr=8-3&keywords=tpms+tool+gm
There are a bunch on Amazon, I went with this one just because it was cheaper:
https://www.amazon.com/gp/product/B076ZL2KDG
That is the one I use, purchased it off ebay 7 years ago and still going strong.
They run about $7 on ebay.
 It does work with 2019  TPMS (315 & 433MHz) as  I swapped mine over to my new wheels today.
My TPMS sensors were GM part# 13522955   433MHz
FYI  - Look at your options code list:
 XL7 indicates 315 MHz TPMS sensors
XL8 indicates 433 MHz TPMS sensors          **** If you do not have either of these codes it is 433MHz.
Edited by Jerry's Denali
Good news! Ordered this TPMS reset tool as per the suggestion above and it does work on our 2019 trucks!
http://www.tpmstoolshop.com/wholesale/el-50448-auto-tire-pressure-monitor-sensor.html
Was $11.27 delivered. I got the Blue one. Arrived in 3 days.
Used the procedure in the manual for TPMS reset and was done in less than 2 minutes.
Thanks for the help. :)
  • 1 year later...
My question is my '19 Sierra 2500HD, today I scored some '19 Silverado 2500hd chrome rims. My el-50448 is not recognizing, do I need different tool? TIA
  • 4 months later...
Will my 2009 Silverado relearn the tpms sensors from a new take off wheels and tires from a 2019 or 2020 Silverado?
The TPMS's will have to be relearned by the vehicle.  The tool is like $10 on Amazon and works great.
  • 6 months later...
Search TPMS Reset tool EL-50448. They're available via Amazon, Ebay, etc. and are inexpensive. I have one and it works with my older GM vehicles (2013, 2017) and my 2019 Silverado.
Is a tool necessary?  Several years ago my tires got rotated, but the shop failed to fix it in the computer.  I read the owner's manual and it said to inflate go through a procedure in the dash first, the adjust the air pressure in the tires on a specific order.  It worked.  Iirc, I let some air out until the horn honked.  After the procedure was done I roller my tires to the correct psi.  I didn't have a tpms test, and assumed they were expensive.  I did have a 25 gallon air compressor and put that to good use.
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
