Putco tail gate light bar
1 minute ago, Jaychevy81 said:
I have the curt on mine I have a 2018 works great
The 55384 linked to above?
  • Replies 50
I saw somewhere where someone tapped the reverse line in the Curt connector between the two 7 pin plugs which is probably what I will do.
That’s exactly what I am going to do prob solder and tape I hate those scotch locks. Just waiting on the NJ weather to change a bit.
Yeah, I'm trying to stay as far away from the scotchloks as possible.  You're just asking for trouble using those.
That’s the exact one I have
Awesome!  I'll go ahead and order one then.
Any idea if that will work on 2018's?  Curt doesn't match it to the 2018's on their site.  Amazon says it will work but I'm leery of trusting them.
I put one on my 2016 and the exact one on my dad’s 2018. Zero issues on either truck.
Also I bought this off amazon I don’t trust the Small sections of double sided tape. Esp in NJ so I’m gonna run one full strip down the light barf2d774f61a644a66bfe96e03a437cca9.jpg
That stuff is great! Just make sure it’s above 45 degrees when you apply it. They call it “permanent tape”
But you can make small adjustments for a few minutes until it really cures.
While I’m waiting to do the install I figured I would clean up the wiring. I didn’t like how it went from the shrink tube to exposed wires to plastic tube. So I wrapped the whole thing in wire loom and taped it with harness tape. It matches the rest of the factory look. I also extended the reverse wire to make it match the Curt T I have installed on the truck now. ac0326d29ac8839b223a2fcd8688d716.jpg
Only thing left to do is show off the finished product!
I know I can’t wait just waiting for a day above 50 here lol tomm it’s 50 but I’m at work lol.
It’s installed bright that’s all I have to say LOL what a difference. Couple things though the harness is def way to long made it hard to keep it neat and out of the way. The second thing I noticed it’s only 57 1/2 inches long overall and then each end is like 1 1/2. Compared to the street glow I had was 60 inches lights to the end. But so be it those are my only issues. The 3m VHB tape is amazing I tried to make a slight adjustment on the one side yea wasn’t happening it’s like weld no joke. Here are a few shots I also changed the reverse bulbs to LED. 7a3ab522461e3d41097c804a39229e4f.jpg554700e28d6dd4ebbcc290d3290f1913.jpg319f680e904f8f16839d727c755ac035.jpgc42563e81de1f8a7d2935a28ab5a0714.jpg
I thought the OPT7 was pricey but this is on another level. I like $50 mods and diys haha
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
