Would like to Trade a set of Black 2020 Silverado tow hooks for a set of Red. Or will buy a set if you have any. Let me know. Thanks
I have a pair of red hooks from a 21 AT4 if anyone is interested.
I’m interested. Are you looking to trade for black?
message sent
Are they still available? I’m interested
If anyone has a “like new” set of black ones for a Sierra laying around after swapping to red that they would like to sell, PM me with what you want shipped to 77494.
Don’t want to trade as I might decide I prefer red after swapping.  But will sell ‘em after swapping if I decide to stick with black.
I’m looking at getting some red ones for mine. Once I get some I’ll let you know, I have the black ones, like new, just got the truck yesterday
Sounds good - thanks!
On 2/22/2020 at 6:39 PM, bdsilverado said:
I just painted mine last week. Provides some red in the dark plastic fog light surround. 20200203_153753.thumb.jpg.eb8d586b06ac0d4cfaa595c90eae74c1.jpg
How do you like the trailer tow mirrors? I just ordered an RST with them and now concerned about blind spots. Love the red truck
  • 3 months later...
I just swapped out my red tow hooks for black on my 2022 LTD AT4.  Anyone interested in the red ones, PM me and I will give you a sweet deal to get them out of the shop.
You'll get use to them.  Only regret is they aren't power folding and don't have cameras.  I may change that in the future.
I’ve got a set of black tow hooks off my 2019 Sierra 1500 if anyone is interested. I’ll cover shipping.
interested. What do you want for them?
  • 8 months later...
If anyone wants to trade tow hooks.  I’ve got black tow hooks on a 19 LT Silverado new body style.  Looking for red tow hooks or can buy them as well
