I just purchased 2019 GMC AT4 and when I backup I cannot hardly see anything even with the camera it is very dark. So what all has worked best after reading all  the post I'm leaning towards the Philips 921 on Amazon. Does the cargo light above rear window need LED bulbs as well I think this turns on when on reverse also? Thanks
You have nothing to replace. The reverse lights on yours are LED from the factory. So are the cargo lights (don’t come on in reverse). Only thing you can swap is the tag lights with 194 LEDs. I used Sylvania on those. Didn’t want something too bright, not trying to illuminate my tailgate going down the road.
I thought they looked bright like an LED but not bright enough, the dealer said they were halogen tells you how much they know. I'm thinking of investing in the tailgate light bar so it shouldn't be too bright for the camera. Did the tag lights help at all? Thanks for the reply, truck is in the shop now the navigation never worked and they replaced SD card, now they have to replace entire radio head unit. Supposed to get it back on Tuesday.
On 3/28/2019 at 8:58 AM, z1boss said:
Correct my original plan was to black out the clear part of the tail lamp but then someone mentioned to me that it will make it harder to see when backing up, which I totally understand so that's why I want the LED bulbs
OEM tinted, blacked out lenses tint the whole lens, not just a portion in addition usually has a black surround. I light tinted the fogs just to match the tinted headlamps, directionals and DRLs, done with magnets epoxied to the back of a 1/8" acrylic sheet attached by magnets to ss washers taped on the fog lens, easy snap on or off.
No way I'm putting in LEDs in the reverse lamps not only for concerns of a parasitic drain on the perimeter lighting circuit if resistance doesn't match, but tinting just the center will look odd at best. It's either do it right and tint the whole housing, unwise,  or not at all. No roads lighting where I live and the HD night vision camera and monitor along with the existing halogen reverse lamps are more than adequate.
Edited by Thomcat
Tag lights were done for looks only, didn’t like them being yellow when everything else was white LED.
I think installing brighter reverse lights (not that you can) or even super bright plate lights could potentially have a negative affect of washing out the backup camera, I noticed this on my 2016. Light bar might do the same, but it might not. Good luck.
I put LED’s in my reverse lights yesterday. Doesn’t wash camera out at all.  Just more light back there.
It’s a tiny little 921 after all.
I know, some of the cheapo Amazon ones really crank out a ton of light still. Also found out the hard way that those don’t last. I put in the boring plain-Jane Sylvanias LEDs in hopes that I don’t have to be out in the dead of winter replacing them. Not any brighter than stock, just white instead of yellow.
Here's the best reason for not substituting LEDs for reverse lamps.......seems the on next gen. models the BCM monitoring of the bulb outage circuits may continue to draw current with key off if original halogen is replaced by an LED. Length of time necessary to kill battery may be dependent upon brand of LED substituted.
https://gm-techlink.com/?p=9594
Just did the reverse and license plate LED swap today with all Phillips. Has anyone noticed any parasitic drain after the swap? Any other weirdness?
Thanks!
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • I bought belts and pulleys for my '20 L5P at Rock Auto a couple years ago. I have used them for many years, and almost always save significant money, especially when I buy maintenance stuff ahead of time.   They carry many OEM parts, which is all I use unless an aftermarket is shown to be same/superior, or if it is an insignificant part or unavailable OEM part anywhere else. RA is usually lower priced, often by a bunch, but parts are sometimes unavailable or out of stock, and I do shop around and sometimes find better prices at other sites.   Be aware that you pay shipping, and if you buy multiple items and they are coming from different warehouses, the shipping can kill the advantage. Planning ahead is best if possible.   If you have a transmission service in the near future, check out their OEM (AC Delco ULV) fluid, usually MUCH less than anywhere else.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
