just got the truck back from dealer  they said they could not duplicate errors and no codes found ...they need it to happen when its at dealer .problem is its so intermittent . called  GM waiting to hear back from them....this really sucks
What is the build date of your truck? Us or Mexico?
Sent from my Pixel 2 using Tapatalk
I don't know I'll have to look and get back to you I got it end of Fed...why?????
Well for example my truck was an early build us truck and has a bad rear window leak which is a known issue with US trucks built before October. If you let everyone know if yours is a 1 Vin or 3 Vin and build date, it might help narrow down the problem if others start experiencing the same thing.
7 hours ago, texasaggies16 said:
time to trade it in on a 18!
I would be to upside down . just made my first loan payment only have the truck 5 weeks
  • Sad 1
1 vin -built-in USA
On ‎2019‎-‎04‎-‎08 at 8:39 AM, Jricharc said:
Jeez, I am reconsidering picking up one of these new models if they are going to be having these issues right off the bat.  Not what should be happening when you spend $40k+ on a vehicle, plain and simple.
Never. I repeat, never. Buy a first MY. truck.
Take that from a Canadian 2014 owner with no lemon law protection.
1 vin -built-in USA
What is the first 3 of the last 6 of your Vin? Mine was 107,xxx meaning it was the 7,xxx th truck built.
255xxx
Well it's been 2 days and I have not heard from a GM supervisor...I guess I will have to call them tomorrow....just show's how much they care about there customers
Mine is 117xxx.  Does that mean my truck was the 117th built?
I could be wrong but I think I starts at 100,000 not 0
All I can say is OUCH - I do know what you are talking about with ghost issues that come and go. I found that it takes a very vigilant service manager to keep on GM to fix the problem. My wife's car (a Chevy Cruze) suddenly died and displayed three unrelated service systems in the DIC. The service manager and the tech both said it was probably one of the computers - but they also had to go through the gm troubleshooting tree before they could replace it. The tree included a couple of reprogramming the computers, replacing the battery cable and inspecting ground points, some sort of relay and finally the computer module - three weeks later. We did have a free rental car during this time and we received status updates from the dealer every other day. We know that they drove it around quite a bit after every repair attempt. The irony of all of this is that it probably cost GM more overall to go through all the steps rather than just replace the computer in the first place.
  • Thanks 1
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,283 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
