next time you bring it in...drive it thru the show room floor....tell them you dont know what the problem was and it appears to be intermitten....I HATE when the demeanor of the dealership changes after you take delivery. I havent been back to the dealer i bought my truck from for that very reason. as i said previously these are issues to the over all perfomance and function of the vehicle, not small glitches.
I didn’t get it back yet. They don’t know what to do. I’ll hear from them Monday because I told the service manager I want to be notified about everything and he will reach out to me on Monday he says. We’ll see
Bummer that sucks that your truck is having issues already.  I'm interested in how this is going to play out.
It is a bummer I almost don’t want the truck back but I will tell all when I find out. I am going to have them write everything down that they did.
  • 4 weeks later...
what ever came of it
Cylinder one was miss firing. So every cylinder has a solenoid. The solenoid went bad and the more they played with it they collapsed a lifter. I got it back and so far so good. I took a 4 hour ride with a car trailer to pick up a new toy and truck operated perfectly. Also handled the car and trailer like a champ
  • 1 month later...
I had the same issue today with the parking brake light coming on and then engine light as well with a rough idle . Brought it to the dealer and they said spark plug wire was loose and now it’s OK they say. Truck only has 62 miles on it. Hoping they’re not full of crap
  • Sad 1
my truck has had a cold start knock since new. Its now at the dealer for a misfire
Edited by ct_corey
  • Sad 1
I have had a number of issues with my 2019 Trail Boss also. The back of my truck is significantly squeaking like the shocks or leaf springs are bad, also hearing a ton of interior noises like rattles, etc. It was a fantastic smooth ride until I put about 5k miles on it. I am headed to the dealership with mine in the next few days.
So has the brakes problems been resolved after a master cylinder replacement? My truck has been back in the shop for 2 weeks waiting on parts!
When I start mine in the morning its has what sounds like a spark knock about 3 of them then all is good and having issues with the radio, the rear end makes a popping noise once in a while also
8800 miles on mine now Custom TB Z71 not 1  glitch,serviced myself  and keeping it that way!!!!
  • 3 weeks later...
I had the value spring problem, but now it’s cutting off by itself. I’m so sad bc I love my truck. I don’t know what to do. Bc I traded my Tahoe that had 85k in miles and never had an issue. Please help if anyone knows anything.
On 4/7/2019 at 7:42 PM, BLUE TRAIL BOSS said:
just want to know if any one else is having problems with there 2019 silverado trail boss...at 50 miles i had all kinds of engine lights on and rough idle, bring it to the dealer the said spark plug wire was not inserted all the way. ok get the truck back and at 106 miles same thing and also hear noises from the rear of truck so back to the dealer I i go . i tell them to keep the truck and drive it for a week  to make sure there are no more issues .so week goes by they give me the truck back said they didn't find anything wrong with it . so i say ok take the truck back all was good till this morning at 640 miles service  esc and parking brake light came on truck ran rough . so i turn it off wait 5 min start it up and all is fine..i guess ill be bring it back to dealer but  don't think they will find anything so frustrated only have it a month and its going back to the dealer for a 3rd time....also parking brake engages it self every now and then...
Bummer, but it sure is a nice looking truck!!
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 484 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
