Build quality by plant?
IMO
Comes down to getting a good one or a bad one.
Doesn't matter where it was built.
  • Replies 38
5 minutes ago, ShamrockShooter said:
I waited it out 3 years and turned it in for a 19 that will will probably be a lemon or buyback inside of 35 days of ownership. All my friends and co-workers that own Ford's just laugh at me
Sent from my Pixel 2 using Tapatalk
Had I read that more carefully, I would have seen that this was already taken care of, lol. Why are they laughing?! The soda cans they drive are just expensive coffins.
                                                           HAHA    "laughing at you..."
My 3 neighbors all drive F150s too. They must think I'm running some sort of illegal Mexican truck smuggling ring. Between my 16, extended test drives, the 19 I bought, and the three loaners since I've had 6 different Silverados parked in my driveway in the past 3 weeks. I have lived in my house for 15 years and my neighbor still has the same F150 he drives every day that was parked there when I moved in.
What's the definition of insanity again? :smash:
I'm a GM guy, but if I had a truck like you had, I certainly wouldn't have bought another GM.
My '14 and '16 were both made in Mexico. The '14 had vibration problems, '16 has been flawless. In my search for a '19, I would prefer a US built truck, but I wouldn't turn down another Mexican made one if the deal was right.
I drove the f150 and didn't like it. Loved the ram more than the 19 t1, but Chevy helped me out a bit from all the troubles I had and ram wouldn't dicker on the loaded Laramie so I went with the 19 trail boss. I have faith gm will make it right. Besides I didn't want to have my Chevy bowtie tattoo removed.
I did notice there is a local Mexican trail boss that is #108 off the line. Production number scares me more than production location for a new model
I would think Ft. Wayne would be the better plant. You want a cheeseburger or an enchilada? I am a Canuck so I like my American food better than Mexican. They only make Double cabs in Ft. Wayne though, all Crews are made in Mexico. My last 3 Ft. Wayne trucks have been great, assembly wise, but these 2014+ GM's are of poor quality in general compared to there 2013- and down trucks.  Sounds like it is the same song and dance with the 2019's. I might ditch my personal half ton altogether and buy a car for the summer.
I've got a 19' Crew Cab RST built in Ft. Wayne...
Yes I believe 14 to 18 all crews were Hecho en Mexico. 19s seem to be split between us and Mexico.
Interesting. I didn't know they switch that up for the T1's. 2018 and down you couldn't get a US built crew cab. They made some 2018 and down crew cabs up here in Oshawa Canada while re-tooling for the 2019's until they shut the plant down completely. I would 100% opt for a Indiana built truck over a Mexican one then if that's the case, even if only from a financial perspective. I am sure the quality is exactly the same.
I have read on this forum that some guys are having paint issues, where were these assembled?  My 2015 1500 4x4 crew cab LT Z71 was assembled in Flint in May 2015. The quality control is excellent and my paint looks like the day it was built, without a single rock chip (38,000 mi.).  The color is Brownstone Metallic.
Dave
My paint seems to be real soft and very easily chipped compared to other vehicles I have owned and driven the same places. My truck was built in Ft. Wayne, 08/18.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
