On 11/11/2019 at 5:30 PM, Trail Boss said:
Same issue... 2019 Custom Trail Boss... @1800 miles, towed to dealer as parking brake would not disengage (computer reprogrammed); 4100 miles, service 4wd and parking brake engaged, was able to get electronic brake to disengage (been at dealer for 2 weeks, replacing actuator and contacts).  Was given a loaner vehicle.  Hoping to get vehicle back soon and that this fix works!
11/16/19 -- vehicle still at dealer, waiting on "new connectors"!!!
Any luck? I'm sitting in a parking lot as we speak, with this issue... and I'm mad as hell. Haven't even made my first payment on the truck yet.
Any luck? Literally sitting in a parking lot with this same problem. Haven't even made my first payment.
Edited by David J. Miller
I have a 2019 GMC Sierra 1500, with all of the same issues, it started when the truck had approx. 1500 km it, now it has 39,000 km and the issue is ongoing with no resolution in sight. This truck has had 4 recalls on it and the transfer case was one of them, still happening almost every time I use 4 wheel drive. I feel your pain I live in Northern Alberta Canada and there is a reason I bought a truck with 4 wheel drive, because I want/need to use it.
Well this hit me today. Driving on a dirt road about 56*F dry conditions. Switched from auto to 2H just before I hit pavement again and got the service 4wd and the orange light for the indicator. Drove home about 5 miles parks and waited for about 5 mins. I restarted and it’s all still there. I take mine to the dealer tomorrow for warranty work on it. I hope it’s a fast fix but these posts don’t seem good.
I'm starting to wonder with the gm plants shutting down for now if the sensor for mine will ever come in. Lol
Hey Guys,
Had the same issue you guys have been reporting, but with a slightly different twist. When I start my truck it gave me the service 4wd message and the 4wd indicator on the dash went yellow. Parking brake engaged. Brought it to the dealer today and the code came back as Transfer Case Control Module C15A9 5A - Range Actuator Position Sensor and Transfer Case Range Position Sensor Not Plausible.
They "Fixed It" by reprogramming the TCCM.
Less than 12 hours later it reoccured.
Is there a fix, and if so what is it???
20 hours ago, Mhugg226 said:
Hey Guys,
Mine is the same code. They tried the reprogramming but that didnt work for mine either. They said it's the sensor now but it's been on national backorder since beginning of February.
So i've contacted the dealer and they are have ordered the sensors and expect them in 3-5 days (highly doubt this will happen).
I've also reached out to GM customer care and im trying to work something out with them. I'm tired of all the headache of this truck. Are the 20's and better? does anyone have any tips for dealing with them?
Good luck, hopefully the sensors come in as that would mean they are no longer on national backorder. As for dealing with them just be persistent but stay polite, they are a pain in the a**. There go to seems to be just call it a software anomaly Lol.
No.  They have their fair share of issues.  If you want a truck with fewer issues, go back about 10 years to the GMT-900s (without AFM) or even the GMT-800s.  Find a low millage and you'll have a GREAT truck!  Or go get a Crapota Tundra :( Sucks to say that but they have the fewest issues out of Dodge, GM, Ford, and Nissan.
Sensors came in and they are currently installing them... hopefully thats the fix.....
Good for you, sucks for me though mine are still supposedly on national backorder. Lol do you know which sensors they are? Maybe you are getting different sensors replaced.
Truck is back and working for now.. they replaced the transfer case range position sensor... truck threw both C15A9 5A and C11AD 08 codes at them
Yup that's the sensor I've been waiting on. Lol
I'm located in Canada, perhaps the Canadian PDC's had stock and the US is out of stock?
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
