2109 Serria denali black window trim
5 hours ago, Josh11 said:
I’m about to replace my windows trims from black to chrome so if anybody is interested in them let me know
You have Sierra or Silverado? I would be interested in swapping my chrome ones off of my ltz
  • Replies 44
Wrapping is 10x cheaper than buying the replacement black ones just FYI. You’re probably looking at $200 to wrap (high side) and easily $75/molding (min) and there’s 3 per door.
Look on ebay they have gloss black covers for the door handles. $50. I just ordered some
How did these black handles work out for you? Saw the same ones and considered ordering. Thanks!
I have not installed them yet. I put them up just to see how they fit and it's not to bad. You can still see a bit of chrome from the top. But not from the side. So pretty good.
What cab, and are these still available?
26 minutes ago, Josh11 said:
It’s a crew cab and yes still available
Alright. Just now realizing the forum topic I’m on. Is it a 2019?
Got mine replaced from black trim to chrome so basically the opposite
Oh ok. I like the chrome on your’s! My truck is silver and I like the look of the black better for a little bit of contrast/a border.
I’m going to try to find out if 2019 trim will fit a 2015, as the window shapes look similar; however, I would imagine they would be different cause of different body styles.
Just placed two pictures side by side comparing, and the dead giveaway is that on the new body style (2019+), they moved the mirrors downward on the door, where the mirror base no longer intersects the window and its trim. So, looks like they would not be interchangeable, unfortunately. Sorry man. Sincerely appreciate the offer and wish you the best.
I will be having the gloss black trim and gloss black center columns from a Sierra AT4 Elevation installed on my Silverado RST during the first week of January.  I ordered the 16 pieces almost 3 months ago and finally have them all in.  I will post pics when complete.
Do you possibly have the part numbers and how much that cost?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
